Author Topic: Not Ground Loop Hum  (Read 5514 times)
Scott Helmke
Re: Not Ground Loop Hum
« Reply #10 on: May 03, 2016, 10:13:56 am »
Would be easy enough to make a little switch/adapter dongle to use with a mic input. Change switch positions for lowest noise, then see if the switch position is in the "all wires normal" position.
Mike Sokol
« Reply #11 on: May 03, 2016, 10:38:09 am »
I think it's easier to just open up to inspect the ends. However, your version could be used to test stage floor boxes for miswiring. I wonder just how many patch panels and floor boxes have been miswired like this?
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Ike Zimbel
    • Zimbel Audio Productions
« Reply #12 on: May 03, 2016, 10:55:50 am »
Well...I know of one situation where an entire splitter / snake system had this problem. Early '90's, so details are hazy now as to whether it was the whole system or just one Mass-con snake. Discovered on a gig, of course. I also worked on a small, independent TV truck that had some tie-lines to the over-the-console rack miswired the same way. That one was painfully obvious to see how it had gone astray: The rack end was a pair of 12 channel stage-boxes bolted together, with one box being the sends (male XLR's) and the other the returns (female XLR's). Whoever wired it (and I'm sure it was a "late at night with the first gig the next day" kind of thing) had laid the boxes face down on the bench and just gone "the shields all go on the right hand pin", which was half right! The really sad thing was that this truck had been in use for a few years when I discovered this.
iz
~Ike Zimbel~
Wireless frequency coordination specialist.
Radio Active Designs
~416-720-0887~
Steve M Smith
  • Isle of Wight - England
« Reply #13 on: May 03, 2016, 01:19:36 pm »
I recently bought some cables which had pin 3 as the ground.  I rewired mine then let the seller know.
Steve.
David Buckley
« Reply #14 on: May 03, 2016, 05:04:11 pm »
Would be nice if someone integrates an LCR meter in an audio cable tester.  That way we can know if shield and hot/cold are swapped or solder connection is poor without taking cable apart.
Doesn't seem hard.  Here's a video demoing a cheap, open source component tester, based on an Arduino, that would be easy to convert into a cable tester.
Or.... stick a pin through the cable jacket.
I can't believe I just said that.
Last year, was the first serious user of a redone venue.  Had lots of newly-installed waylines, and every single XLR wayline was crosswired.  My theory is that they mis-wired the first wayline, then used that as the "send" line, and used a XLR cable at the far end to patch it to another wayline for testing.  Because the first one was wrong, to get the tester to show "OK" they had to miswire every other line.  Ticked the big box that said "all tested".
We complained to the venue of course, heck, I had a list of things done wrong.  I'm told the venue employed an independent contractor to watch over the installer as they re-terminated and retested each line.
« Last Edit: May 03, 2016, 05:06:56 pm by David Buckley »
Mike Sokol
« Reply #15 on: May 03, 2016, 06:25:11 pm »
As you note, the problem is that two mis-wired connectors can fool a continuity tester into passing a cable run with the shield wired pin 2 or 3. Since testing UTP CAT-5 for proper twists is pretty common and inexpensive, I wonder if there's some way to utilize that type of testing technology for XLR cables.
Mike Sokol
www.NoShockZone.org
Ike Zimbel
« Reply #16 on: May 03, 2016, 08:55:31 pm »
Hmmm...it might be as simple as a pair of XLR to RJ-45 adapters wired as one pair of the 4...but I don't have one of those testers to try it with so I'm just speculating  :-\
~Ike Zimbel~
~416-720-0887~
Stephen Swaffer
« Reply #17 on: May 03, 2016, 08:56:13 pm »
The reason that mis-wiring is an issue is because noise is capacitively (I think-JR can correct me maybe inductively?) coupled to the shield.  A tester that intentionally couples a noise source to the shield should be able to identify the pin the shield is connected to-then all that is needed is a simple pin to pin continuity test.
Steve Swaffer
Mike Sokol
« Reply #18 on: May 03, 2016, 09:02:05 pm »
It's a little more complicated than that, since the twisted pair must be close enough together so they have the same outside noise coupling so it can be cancelled by the CMRR (Common Mode Rejection Ratio) of the balanced input circuit.
Mike Sokol
www.NoShockZone.org
« Reply #19 on: May 04, 2016, 09:34:22 am »
It seems electrostatic (capacitive) coupling would be the dominant mechanism.
It "might" be as easy as measuring the capacitance between pairs of leads. I would expect the C between 2-3 to be different than 2-1 or 3-1, but this is pure speculation.
My cheap rat shack VOM has a C meter built in.
Page created in 0.041 seconds with 22 queries.
