Pages: 1 ... 9 10 [11]   Go Down
Author Topic: Loud Guitar Amps  (Read 21520 times)
Dave Dermont
  • Forum Moderator
  • Global Moderator
  • From The Great Pocono Northeast
Re: Loud Guitar Amps
« Reply #100 on: April 23, 2016, 07:54:56 pm »
We need to separate the fact from the fiction here.
First of all, if you are Stevie Ray, or Angus, or Eric, you can play as loud as you want, whenever you want, wherever you want. Those not on the "10 Best Of all Time" list need to get a clue.
There is a difference between "I need my tone" and "I love to swim in audio".
...and another thing
The same drum hit with the same force with the same stick will produce the same energy, no matter what room you are in. A difference in room size and how live/dead that room is will change how that energy is perceived by your ear.
Once upon a time, I did a gig in a brick and glass room where the largest dimension was the 60 foot ceiling. After sound check, I told the drummer, "The drums sound good, but everything sounds like -When The Levee Breaks-".
Listen, if you have been playing a musical instrument since the 60s and still have no understanding of dynamics, that's your damn problem, not mine.
Getting back to the original post...
You say it was a packed house, so that's good. You want to make it better. That's good too.
Just moving the mix position and not adding delay stacks will not keep the front of the room from being crushed with guitar. It will also likely put you past the critical distance where you are hearing more reflected than direct PA sound.
Are delay stacks for a bar gig worth the effort?
Will they really help, or will they just make it so everyone is equally crushed with guitar?
Is the house packed because these people love being crushed with guitar?
Only you can answer these questions.
Players who bring people through the door deserve special dispensation. Even local guitar gods.
We are not hired to be critics. We are hired to do gigs to the best of our ability.
Have fun. Thanks for caring.
Dave Dermont
Warning: Dates on calendar may be closer than they appear
David Buckley
« Reply #101 on: April 23, 2016, 09:00:46 pm »
Tim - it wasn't until I got the free Blue Cat Frequency Analyzer plug in that I started finding horrible amounts of LF and HF in modeled guitar amps, some of my older synths, etc. Not so much from an e906 in front of a guitar cab.
There certainly is, but the same is true if one has a DI off a guitar amp speaker, the sound is all sizzle.  And its sizzle that cant be fixed with normal EQ, it needs LPF or a crossover band applying to tame the mess.  A guitar amp speaker is not a full range device.
And I'm a big fan of power droppers, like the Palmer, or just home made out of a bunch of resistors; its not perfect, but its good enough.
Guy Luckert
« Reply #102 on: April 24, 2016, 06:37:38 am »
I am a fan of a miked tweed Deluxe-lack of headroom is a beautiful thing.
sound good-not loud
mike it
Steve M Smith
  • Isle of Wight - England
« Reply #103 on: April 25, 2016, 02:45:14 am »
sound good-not loud
mike it
That would work for me.  I play rockabilly rather than rock, but I like just enough volume for a hollow body guitar to be just on the edge of feedback for a bit of amp to guitar interaction.  I can do this with a 17w amp using two EL84s.  No more is required.
Steve.
john lutz
« Reply #104 on: April 25, 2016, 10:58:23 am »
A sub category of too loud guitars seems to be the clean vs. overdrive sounds.  Why do so many players who suffer from too loud for the stage, also have their clean or rhythm sound so much louder than the lead or drive sound?
« Reply #105 on: April 25, 2016, 11:01:42 am »
More to the point - how can they not tell the levels are radically different?  Why are they not offended?  Because they stop when they find the majik voodoo tone.  Growth of technique and musicianship then congeals like yesterday's gravy.
Bob Leonard
  • Boston, MA USA
« Reply #106 on: April 25, 2016, 11:20:59 am »
Today I found a video that illustrates this discussion very well. More than just guitar, but also a good view of shielding, monitor placement and technique.
https://www.youtube.com/watch?v=ObJCtCmmi7w&nohtml5=False
BOSTON STRONG........
Proud Vietnam Veteran
Stephen Kirby
« Reply #107 on: April 25, 2016, 01:48:09 pm »
That's because the overdrive compresses and the clean doesn't.  So what might initially sound like similar levels played gently turns into the clean being much louder once they start playing.  Especially folks who play with tons of gain which makes anything they do sound pretty much the same.
I remember having a conversation with the CTO of a company that made a specialized computer for running music plug-ins and models.  His opinion was that most modelers had nowhere near enough resolution to deal with the artifacts of digital distortion models and that much of the buzz was aliasing that even rolling everything above 5k off with a speaker emulator plug-in wouldn't cut out.
Pages: 1 ... 9 10 [11]   Go Up
Page created in 0.057 seconds with 22 queries.
