Pages: 1 2 [3] 4   Go Down
Author Topic: Help Please!: Danley Sound Labs System Purchase  (Read 11079 times)
John Rutirasiri
Re: Help Please!: Danley Sound Labs System Purchase
« Reply #20 on: April 04, 2016, 05:20:39 pm »
And if you need more output- you can do a quad SH46 with a single hang point
That's not a sound system...that's a WMD!
John R.
Sound/Lighting/Corporate A/V
Caleb Dueck
« Reply #21 on: April 04, 2016, 08:56:56 pm »
I would echo Ivan and Jeffrey, SH96/SH96HO/SH46 for tops.  SM80 over TH118 for monitors. The only weak point are the subs, 4x DBH are great but not loud enough.  8x would do better, maybe the -LC version if the BC218's  are out of budget.
John Rutirasiri
« Reply #22 on: April 04, 2016, 10:21:57 pm »
If you're anywhere close to Bakersfield, stop by Freestyle Event Services.  They are a dealer and have production experience with various Danley boxes.
Although you won't go wrong with any Danley, you should talk to the people who use them regularly and get their input.  Sometimes what you want may not be what you need.
John R.
Ted Christensen
« Reply #23 on: April 04, 2016, 10:49:38 pm »
The only thing i dont like about the sh46 flyware is the pick points do not have any angles numbered. Its just blank with lots of choices. I use it all the time with my sh46s.
Danley SH46 / Th115 / EV ZX5 / EV QRX212H / QSC HPR / Lab Gruppen / Chauvet / Blizzard / Allen and heath ilive
Ara Ayrassian
« Reply #24 on: April 05, 2016, 02:26:06 am »
John R.
If you are down in the Santa Barbara area I use SH96HO's and DBH218 subs I can do a demo for you I'm also a dealer.
Danley SH96HO's 2 DBH218 powered ,SPL td-1's  Danley DSL P48 processor 2 x Danley THmini 15 subs 4 SM100's 2 SH50's and Ashly Protea 4.24C ,Crown tech 6000, Crown MA12000i QSC PLX 3602 , Crown xdi 6002, EAW JF80 x 4 Altec A6 VOTT, EVZXA1's
You can be right with a wrong spirit so listen carefully.
John Rutirasiri
« Reply #25 on: April 05, 2016, 09:15:10 am »
10-4 Ted, although it's usually the last or 3rd from the last one for me...
« Reply #26 on: April 05, 2016, 11:09:19 am »
The MB50 bracket is used for several different products-so each one would be different.
Also you can use it to fly 2 or 3 (or more if you want) wide cabinets.
Each configuration would be a different angle.
It is simple enough to either throw a level (or phone app) on the cabinets or simply look at where it is aimed.
You don't need to get "hung up" with the angles as much as with a line array-because the vertical coverage is so much taller.
Ted Christensen
« Reply #27 on: April 05, 2016, 11:42:53 am »
If i need to use Danley design software and am wanting to cover a specific area it would be beneficial to use pre marked angles to only hang the box once.
Stephen Kirby
« Reply #28 on: April 05, 2016, 12:20:36 pm »
I would think that if you're only using the flyware on one particular rig, it would be easy enough to use an angle indicator (Harbor Freight) or phone app to measure how it hangs and mark the holes.
Ted Christensen
« Reply #29 on: April 05, 2016, 12:38:06 pm »
I would think that if you're only using the flyware on one particular rig, it would be 6easy enough to use an angle indicator (Harbor Freight) or phone app to measure how it hangs and mark the holes.
Agreed, i dont own genies. I rent.  I have no other way to fly them.
Pages: 1 2 [3] 4   Go Up
Page created in 0.042 seconds with 23 queries.
