Pages: 1 2 3 [4]   Go Down
Author Topic: Any djs using Danley SM 80's  (Read 13688 times)
Ara Ayrassian
Re: Any djs using Danley SM 80's
« Reply #30 on: January 07, 2016, 02:40:07 pm »
And they are variable (to an extent)-at least in speed------
I am wondering about the SM80 for DJ use I always like the slam that horn loaded cabinets hit in the 100Hz-160Hz range this is why I like the SPL td-1's and DBH218's set up I have or the SH96HO's depending on the venue size.
Danley SH96HO's 2 DBH218 powered ,SPL td-1's  Danley DSL P48 processor 2 x Danley THmini 15 subs 4 SM100's 2 SH50's and Ashly Protea 4.24C ,Crown tech 6000, Crown MA12000i QSC PLX 3602 , Crown xdi 6002, EAW JF80 x 4 Altec A6 VOTT, EVZXA1's
You can be right with a wrong spirit so listen carefully.
John L Nobile
« Reply #31 on: January 07, 2016, 03:39:13 pm »
Don't think you'll get that slam as SM80's roll off at 160 hz.
Tamar Ghobria
« Reply #32 on: January 08, 2016, 05:43:43 am »
I ended up getting the SM 80 over 118.....Now looking for the right amp....Leaning towards Powersoft or Lab Gruppen....Also considering the QSC PLD....I am hoping to find something where I can set how much power I am pulling from the wall....I know the Powersoft has that feature
Doug Fowler
  • Saint Louis, MO USA
« Reply #33 on: January 08, 2016, 11:59:08 am »
Just use a clamp on ammeter when your system is running at its limit.  Keep it simple (and cheaper).
Lance Hallmark
  • Tampa Bay, FL
    • Hallmark Events & Entertainment
« Reply #34 on: September 27, 2016, 04:42:39 pm »
I ended up going with a JTR rig, 2 Noesis 3TX (4ohm) over 2 Orbit Shifters (2 ohm). Loving it, tops are very loud & clear, the three way config brings out a lot of nuances of the tracks I play. Bass is  awesome, musical. Even at low volumes you can feel the low frequencies throughout the room.
The more I'm reading, it seems that the Danley 20k4 amp is the way to go. Lots of limiting options, including voltage, for protection, plus full DSP optimized for your specific speakers. Pick up a couple of back up amps in case of failure until you can get two of them. Buy once, cry once applies again. I'm going to look into getting one for the system listed above once I've started bringing in some more revenue from the P.A. I'm currently using 2 Crown XTI 6002s, one speaker per channel and would keep them as backup.
Lance Hallmark
Chamsys, Crown, Danley, EV, JTR, Powersoft, Yamaha
Pages: 1 2 3 [4]   Go Up
Page created in 0.024 seconds with 22 queries.
