Pages: [1] 2 3 4   Go Down
Author Topic: Any djs using Danley SM 80's  (Read 13725 times)
Tamar Ghobria
« on: December 13, 2015, 09:06:24 pm »
I see the rave reviews but its mostly from Bands...Would love to know how these hold up with heavy EDM Style music....I had the Danley Sm 96 over TH 118 combo and I had an issue where the tops would go into a protect mode and temporarily cut the output down....SM 96 has a higher spl and should cut the room more but would love to hear feedback
Scott Carneval
    • Cenero Audio Visual
Re: Any djs using Danley SM 80's
« Reply #1 on: December 13, 2015, 09:23:05 pm »
What size rooms are you trying to cover? How many people? Are you currently using one TH118 per side? And are you happy with that output? Because the SM80 will easily outrun a single TH118. You would need 2-3 TH118 per side to keep up with a SM80, at least for EDM and/or Hip-Hop.
I don't really subscribe to the 'this speaker is better for this type of music than that speaker' notion. If a speaker is relatively flat and reasonably accurate in response it should sound good no matter what you're using it for.  And yes I have used the SM80 for EDM, and it sounds great.
Tamar Ghobria
« Reply #2 on: December 13, 2015, 09:49:57 pm »
Rooms vary in size but I provide sound a for a lot of djs where its never enough for them....I was running one th-118 per side with the 96's....mostly edm style music...I work in different rooms...varying number of people....biggest would probably be 1500
Robert Piascik
« Reply #3 on: December 13, 2015, 10:39:29 pm »
I agree with Scott above. I have SM80 over TH118 set up and while I don't provide much for EDM type events if I need a big sound I use 2-3 subs per top. 2 tops and 6 subs powered with IT8k would fill up a pretty good sized room. I think the problem is not SM96 vs. SM80 it's not enough sub to balance.
Pi Entertainment Services
Midas M32R / MR18
Behringer X32R / XR12
Fulcrum Acoustic fa22ac
RCF NX 12SMA
Yamaha DSR112 / DZR10
Powersoft X4 / M50Q
Crown iT8k / Xti6k
Steve M Smith
  • Isle of Wight - England
« Reply #4 on: December 14, 2015, 04:40:08 am »
Never enough for them is usually more than enough for everyone else in the room.
Steve.
« Reply #5 on: December 14, 2015, 01:25:01 pm »
Steve.
+100
Tamar Ghobria
« Reply #6 on: December 14, 2015, 03:49:08 pm »
sorry typo...sm 80 has a higher spl
Doug Fowler
  • Saint Louis, MO USA
« Reply #7 on: December 14, 2015, 04:04:04 pm »
2x TH-118 + SM80 per side for EDM = a few hundred people, depending, from experience.  And sound fantastic, of course.  Be aware SM80 has very limited LF, so proper xover setup is crucial.
Keith Broughton
  • Toronto
« Reply #8 on: December 14, 2015, 05:03:15 pm »
I am curious about the SM96 vs SM 80 as well.
Heard a rig with 2xSM80 over 6 TH118s and it sounded spectacular.
Installed 20 OS80s in an arena and it sounded great.
However, it seems to me the SM96, while a couple of db down, has better low freq. response and might have better low freq. pattern control.
« Reply #9 on: December 14, 2015, 05:12:45 pm »
Here is a bad video of 2 SM80s and 2 subs (BC218) outsde about 100' away.
You can read some of the numbers in the comments
https://www.facebook.com/ivan.beaver/videos/vb.100000581642030/1070611356301576/?type=2&theater
Pages: [1] 2 3 4   Go Up
Page created in 0.061 seconds with 23 queries.
