Pages: [1] 2 3 4   Go Down
Author Topic: Helical Antennae: RHCP/LHCP  (Read 10155 times)
Tim Steer
« on: November 18, 2015, 04:50:43 am »
When setting up a wireless link using a transmitter and receiver with two helicals facing each other, should both antennas be RHCP or should I be using a LHCP/RHCP pair?
I'm sure this is a simple question to someone who knows about these things, but I'm afraid what I know about RF engineering could be written on the back of a napkin. From what I've gleaned from model aeroplane forums it sounds like both antennas should be identical, and choosing the wrong combination can result in a 30dB loss in received signal, but I wanted to get the opinion of some people in the industry, as one company I work for uses a RHCP/LHCP pair for wireless audio links (to my mind this intuitively 'seems wrong' as the 'threads' won't 'wind on' to each-other, if you catch my drift).
This begs the questions, what is the practical difference between RHCP/LHCP, and why might a company have equal numbers of both types in their hire-stock?
Scott Helmke
Re: Helical Antennae: RHCP/LHCP
« Reply #1 on: November 18, 2015, 09:57:14 am »
You want to use the same handedness / "sense" on both. Think of it like nuts on a threaded rod.
There is attenuation from the polarity mismatch when mixing the two types. A practical application might be putting IEM transmitters on LH and wireless mics on RH to reduce interference between the two.
Pete Erskine
    • Best Audio
« Reply #2 on: November 18, 2015, 12:12:10 pm »
This brings up an interesting question.  Maybe Henry Cohen can answer.
If the 2 Helicals are facing each other should one be RH and the other LH for aligning the polarity?  Is the polarity mirror image?
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Keith Broughton
  • Toronto
« Reply #3 on: November 18, 2015, 12:17:28 pm »
Good question.
As for the OP, in a wireless link situation where antenna polarity can be fixed, is it worth using  helicals or would LP (fins) be fine?
  • Old enough to know better
  • Audio Plumber
« Reply #4 on: November 18, 2015, 12:23:14 pm »
Which way they are facing does not affect the polarization. As a point to point link they should have the same polarization (twist). To minimize cross interference between IEM transmitters and mic receivers they should have opposite polarization (twist).
Tim Steer
« Reply #5 on: November 18, 2015, 12:36:59 pm »
Thanks, that's how I imagined it to be.
Good question.
I take your point, but it's a somewhat hypothetical situation that just interested me.
Makes total sense. Thanks everyone.
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #6 on: November 18, 2015, 02:48:07 pm »
The idea of thinking of it like a bolt really helped me visualize this.  But thanks for confirming that.
Oh, and how much fun is it to answer an RF question posed by Peter Erskine?  :)
brian maddox
bdmaudio@gmail.com
Henry Cohen
  • Westchester Co., NY, USA
« Reply #7 on: November 19, 2015, 04:05:51 pm »
Not nearly as much fun as when he asks at which BBQ place we should eat  ;D
Henry Cohen
  • Audio Plumber
« Reply #8 on: November 19, 2015, 04:16:17 pm »
Big W's Roadside BBQ in Wingdale NY. I've already dragged Pete there, he cam away a believer.
Steve M Smith
  • Isle of Wight - England
« Reply #9 on: November 19, 2015, 04:21:25 pm »
I was going to suggest a length of threaded rod as an analogy. Rotate it 180 degrees and it is exactly the same.
Steve.
Pages: [1] 2 3 4   Go Up
Page created in 0.032 seconds with 22 queries.
