Pages: [1] 2 3  All   Go Down
Author Topic: The science of line arrays...  (Read 6803 times)
Al Rettich
« on: October 10, 2015, 05:16:06 pm »
As I've been taught over the years about how intensity shading is bad for line arrays, what about fixed angles? I've read how most manufactures created a "fixed" angle line array to take out the calculations (aka dumb-a-fy) of doing a proper line array. But two boxes doesn't make a line array, as well as fixed angles. So why have portable line array's that are fixed angles? Just so you can offer a line array?
Your thoughts?
Jelmer de Jong
Re: The science of line arrays...
« Reply #1 on: October 10, 2015, 06:06:09 pm »
Fixed angle is the way to go from a engineering standpoint. You can't build a box that has a 10 degree dispertion on one day and a 2 degree dispertion on the next day.
When you look at modern linearrays they are all used 90% of the time with lots of overlap between boxes, only the bottom few have enough tilt between them to not interfere to much with each other.
« Reply #2 on: October 10, 2015, 06:37:07 pm »
Here are a couple of the "basics" for having something that actually "arrays well".
1: Look at the angle of the cabinet.  It should be 1/2 that of the rated coverage angle.
So if the rated coverage is 20*, then it has to be cut at 10* to be arrayable,
2: The size of the horn MATTERS!!
It takes SIZE to have control (so that one cabinet does not interfere with the others)
The problem is that the NARROWER the horn coverage, the LARGER the horn has to be to have the same control as a wider coverage horn.
Let's say you have a horn that is 16" tall and rated at 20*.
It will have pattern control down to just over 3KHz.  Below that the different cabinets will start to interfere with each other.
The same size for but rated for 40* would have control and octave lower or around 1.5Kz.  80* would get you down to 750Hzish
Of course if the horn is narrower and smaller-then that freq will be higher, which makes things worse.
Believe it or not (many people do NOT want to), loudspeakers DO NOT have the rated pattern across the freq range they are used at.
In many cases, the rated pattern is only for the top octave or 2 of the HF driver.  And in the usable range of the HF driver, it starts to lose pattern control. Forget about the mids, much less the lows.
But at least the lows (in many cases) are close enough together (within 1/4 wavelength) that they couple (assuming the lows don't go to high)
So the loudspeaker just ends up "spewing sound" all over the place, bouncing off of things you don't want it to.
It takes SIZE to control wavelength, no way around that.  Unless you just want to believe what the marketing dept tells you.
BTW I have some ocean front property in Kansas if you are interested---------------------
Jason Raboin
    • Klondike Sound
« Reply #3 on: October 10, 2015, 07:15:37 pm »
Ivan, ren't there some exception to this rule?  I don't know the engineering behind it, but my Fulcrum Acoustic FA22AC have a fairly small horn but have pattern control down -12 @ 400hz.  That's based on their product specs but also based on my real world experience.
I don't have the plots to back it up, but L'acoustics ARCS have very impressive pattern control with only a 22.5* rated horizontal dispersion and a fairly small horn.  How is this achieved?
Jason Raboin
Partner
Klondike Sound
« Reply #4 on: October 10, 2015, 08:58:36 pm »
I am not aware of any exception.
Again, it is not only the size of the horn, but ALSO the pattern.
For two horns of the same size-the one with the wider pattern will have freq control down lower.
So a narrower horn HAS to be larger to maintain the same pattern as a wider horn.
The basic math is  Freq of control=1,000,000/(size of horn in inches x rated pattern in degrees)
This is a rough estimation.
If there is some way to control without size (relative to the wavelength involved), I would LOVE to hear about it.
There is no "magic" being done by anybody-that I am aware of.
Peter Morris
« Reply #5 on: October 10, 2015, 09:40:14 pm »
Vertically the horn starts to lose control at about 2KHz.  Below the crossover point of the horn (around 1000Hz) its the dipole action of the 2 x 12" drivers that help maintain some vertical pattern control down to around 400Hz.
« Reply #6 on: October 10, 2015, 09:53:34 pm »
And therein lies the whole size thing.
Drivers that are properly spaced can change the pattern being radiated.
But to go lower and lower the spacing has to be larger and larger.
So the "size" is larger with lowering freq.
Just like waves in the ocean.  You cannot "control" large waves with small barriers.  It takes large barriers for large (low freq) waves.
Keith Broughton
  • Toronto
« Reply #7 on: October 11, 2015, 06:31:22 am »
Good one! :)
I have to remember that whey trying to explain pattern control.
« Reply #8 on: October 11, 2015, 09:13:09 am »
Good one! :)
Here is another way to "look" at it.
Go to the ocean and find a pier.
Notice how there are basically 2 sizes of waves.  The obvious large ones (caused by the tide), and the smaller ripples (caused by the wind).
The large ones are low freq and the small ones high freq.
Now look at the area around one of the pilings on the pier.
Notice how on the opposite side that the wind is blowing, there is a calm area (in respect to the small waves) behind the piling, where it is being shadowed.
The piling is large in respect to the size of the wind waves.
But ALSO notice that the large wave is completely unaffected by the piling.  It is still the same size and shape
It takes something MUCH larger to control or affect the larger wave.  A large barrier -in respect to the size of the wave.
As it is in audio, the larger the wave (lower the freq) the more "stuff" it takes to either control or affect it.
This goes for either pattern control or acoustic treatment.
DO NOT expect to put some fuzz on the wall and control low freq.
It takes SIZE.  So the best you can hope to do is to "break it up" rather than absorb it.
Once you start to think about sound in terms of wavelength SIZE, all sorts of things start to "come together".
Don't think freq, think SIZE OF THE WAVEFORM.
Go out in your drive wave and draw a single cycle of a 50Hz (or better yet a 20Hz) wave to get an idea of how LARGE we are talking about.
For those who don't want to do the simple math, 50Hz is roughly 22 feet for a single cycle and 20Hz is roughly 56 feet-for a single cycle.
And 10 Khz is less than an inch   That is easy to draw and control
YES SIZE MATTERS
« Reply #9 on: October 11, 2015, 09:44:35 am »
Reflecting on the topic title, isn't "the science of line arrays" an oxymoron?  :o
Sorry just trying to make a joke about the compromises involved....
Of course they behave as defined by physics just like all speakers.
Pages: [1] 2 3  All   Go Up
Page created in 0.052 seconds with 22 queries.
