Author Topic: Fiber Polarity on an audio network (Yamaha/Dante)  (Read 4209 times)
John Penkala
« on: September 14, 2015, 04:40:15 PM »
      I am building racks for a multiple Yamaha RIO/Dante network. I'm using Cisco SG300 troughout the network with the LX GBIC modules. I have some panels fitted with OpticalCon Duo connectors that use either LC (A to A) or LC (A to B) patch cables. Currently, I am planning to use the LC (A to A) patch cables inside the racks and reverse the polarity on the long fiber cables (500-1000ft) used to connect the different racks together. This seems to be the most logical way to configure the system as there will be many different racks used in different configurations.  Is there a standard or best practice for configuring fiber or is whatever works the norm? Thanks.
JP
  • Old enough to know better
  • Audio Plumber
Re: Fiber Polarity on an audio network (Yamaha/Dante)
« Reply #1 on: September 14, 2015, 07:34:16 PM »
JP
If it was me, I'd have the cables be straight through in case you have to extend them. A-B cables change their configuration every time you extend them.
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #2 on: September 14, 2015, 11:36:12 PM »
I have really only used fiber in installs so I haven't ever thought about this.  Do you need to have A racks and B racks.   Where one is normal and one is reversed?
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
  • Audio Plumber
« Reply #3 on: September 15, 2015, 01:23:21 AM »
Yes, but isn't that how you go about wiring a network anyway?
John Penkala
« Reply #4 on: September 15, 2015, 09:32:39 AM »
Mac,
      I was hoping you would respond.  Thank you. You got me thinking.  I think I should designate one pair of fiber connections on the panel as inputs and the other pair as outputs. I could then use the reversed polarity LC patches (A-B) just on the inputs of all of the racks and keep the outputs wired (A-A) and use straight (A-A) cables to connect the racks. I'm guessing this is how it's normally done.
JP
Bob Leonard
  • Boston, MA USA
« Reply #5 on: December 28, 2015, 10:07:00 PM »
Correct, and depending on the manufacturer the panel will be enclosed and partitioned to segregate the ins from the outs, the A from the B. Don't skimp on the panels.
BOSTON STRONG........
Proud Vietnam Veteran
Page created in 0.105 seconds with 21 queries.
