Author Topic: Sennheiser N antenna cables, watchout  (Read 4358 times)
Jens Palm Bacher
    • Lydfabrikken
« on: July 26, 2015, 03:39:59 PM »
Just found an Aircell 7 HF cable with N connectors from Sennheiser with the centerpin too far forward. It has caused 2 broken connectors on our Sennheiser 9000 antennas, watch out...
Keith Broughton
  • Toronto
Re: Sennheiser N antenna cables, watchout
« Reply #1 on: July 26, 2015, 04:14:16 PM »
Noted...thanks  :)
Jason Glass
    • CleanWirelessAudio.com
« Reply #2 on: July 26, 2015, 07:53:55 PM »
Thanks for the info!
I harp on the guys that I work with constantly about extended and retracted coax pins.  I'm sure that they're tired of hearing about it from me.
Jerome Malsack
« Reply #3 on: July 27, 2015, 03:02:23 PM »
A picture of the correct position on the center pin would help me the novice.
Could someone please post a correct pin for comparison ?
Henry Cohen
  • Westchester Co., NY, USA
« Reply #4 on: July 27, 2015, 07:34:13 PM »
This is a problem with all air dielectric coax (Belden 9913, Wireman CQ102, etc): The repeated coiling and uncoiling causes the center conductor to walk. Especially bad on shorter cables. This type of coax was never designed for repeated deployments. I'll bet the other end of Jens' coax had the pin recessed too far into the connector.
Henry Cohen
Jens Palm Bacher
    • Lydfabrikken
« Reply #5 on: September 12, 2015, 02:56:11 PM »
In this case it was just bad manufactoring, both ends was too far forward.
Page created in 0.17 seconds with 24 queries.
