Author Topic: iMacs and USB port issues  (Read 1513 times)
Stephen Swaffer
« on: July 16, 2015, 10:19:57 pm »
We started using an iMac for our main media computer last winter.  Two issue with usb I have run into.
First, incompatibility with USB hubs.  I have all USB ports in use, plus plugging in to the back is a pain.  I bought a hub that was supposed to be Mac compatible, but the iMac refuses to recognize it.  Recommendations for a reliable hub?  Preference is with its own power supply.
Secondly,  last Sunday with no changes between a video preview on Sat night and Sunday AM, our Scarlett 18i20 refused to connect.  Ultimately, swapping USB cables did not help-and plugging the mouse into the port the Scarlett had been attached to seemed to indicate that port was dead.  Eventually, I got the Scarlett to work on a different port-and then finally on the original port.  No software or setting changes.  Obviously, I have my misgivings in relying on the current status quo going forward.
Thoughts?
Steve Swaffer
Milt Hathaway
    • http://www.fitzcosound.com
Re: iMacs and USB port issues
« Reply #1 on: July 16, 2015, 10:39:14 pm »
If it's an iMac with Thunderbolt capability I would look into running something like a Thunderbolt dock or Thunderbolt to USB adaptor. This will give you external USB ports that are not dependent upon the (apparently flaky) ones internal to your iMac.
There are a number of Thunderbolt docks out there that in addition to giving you additional USB 3.0 ports will also add more external display ports, firewire ports, and ethernet ports.
Milt
FitzCo Sound, Inc.
Midland, TX
Page created in 0.054 seconds with 24 queries.
