Author Topic: Weekend warrior truss - education needed  (Read 5676 times)
Mark Cadwallader
  • Helena, Montana USA
Re: Weekend warrior truss - education needed
« Reply #10 on: June 17, 2015, 08:10:00 pm »
If you get mounting brackets for apex up triangle truss, square truss will also fit in the same brackets.
The downside of apex up (pun intended) is that your lights are not going to be centered on the load of the truss.  Depending on the stands you use, this may or may not be an issue.  Note that square truss has the same problem no matter what.  Hang a few lights on the front bar and a few on the back, and problem solved.
With adjustable brackets I also have the option of moving the CofG more towards the centerline of the stands by moving the loaded chord towards the center. (The shift is about 5", which is pretty good for 12" truss.)  I don't know if anyone else has tried this; YMMV.  Be careful with overhead loads....
Rob Gow
« Reply #11 on: June 18, 2015, 03:58:02 pm »
I use a similar version of Aluminum triangle truss (I'm
In Canada) two 8' sections with ST-132 stands fits 11 Blizzard 3NX's nicely. I use 11 because then I can work off a center light when using alternating colors.
Don't forget the safety cables.
« Last Edit: July 02, 2015, 09:41:06 am by Rob Gow »
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #12 on: June 18, 2015, 07:33:56 pm »
In Canada) two 8' sections with ST-182 stands fits 11 Blizzard 3NX's nicely. I use 11 because then I can work off a center light when using alternating colors.
Those look like ST-132s
Rob Gow
« Reply #13 on: June 18, 2015, 09:03:14 pm »
Ah ok. I tried to find the equivalent. They are actually Players Choice DLC001
I'm Canadian, different market. Probably from the same factory in China.
http://www.axemusic.com/lighting/lighting-accessories/lighting-stands-truss/players-choice-dlc001-light-stand-13-180lbs-capacity-steel.html
Rob Spence
« Reply #14 on: June 19, 2015, 12:40:41 pm »
ST132 is 13'2" with tripod legs
ST180 is 18" with outrigger legs
Rob Gow
« Reply #15 on: June 19, 2015, 01:20:01 pm »
Ahhhhhh ok. The ST132 is the similar one. I was confused, these go to 13 feet as well.
The point was more the truss. It can be held up by whatever you choose.
Works great.
Page created in 0.041 seconds with 24 queries.
