Author Topic: Racking Powersoft K2 and K3 amps  (Read 2847 times)
Patrick Campbell
    • Jury's Out Rock Band
« on: May 27, 2015, 01:10:53 pm »
Hey everyone,
When you rack Powersoft amps, do you put a space between them for possible thermal issues ?
I want to got from my 20 space amp rack full of QSC amps, down to FOUR Powersoft amps and DR260 and backup that I can fit in a 6 space rack ???
Any experience is welcomed with this downsizing move
BTW, I got QSC RMX 5050 amps for sale and a 20 space amp rack -ha
Thanks again,
Patrick
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
Re: Racking Powersoft K2 and K3 amps
« Reply #1 on: May 27, 2015, 02:26:48 pm »
Hey everyone,
Thanks again,
Patrick
I've seen them done both ways, but I've never heard of a problem with them while tightly spaced. I'd say go for it and just be sure that the rack can breathe.
gordonmcgregor
« Reply #2 on: May 27, 2015, 03:25:18 pm »
As long as there's PLENTY of front to back airpath then you have no need for gaps in the racks between amps. I suspect the newer ones will run even cooler than the older versions, the biggest issue I've seen is a 1or2u patch panel mounted on the back can easily restrict the air flow enough to have the amps fans running harder than usual. I also have to say i've never seen one thermal out either even under serious abuse. G
Lee Buckalew
  • St. Louis, MO area
    • Pro Sound Advice, Inc.
« Reply #3 on: May 27, 2015, 03:34:50 pm »
Hey everyone,
Thanks again,
Patrick
I routinely see 8-12 in a single rack with no spaces.  Higher quantities than that I usually see them in groups by application (subs, LF, MF, HF) or with small spaces between them in large amp rack rooms.
Lee
Lee Buckalew
Patrick Campbell
« Reply #4 on: July 28, 2015, 11:22:59 am »
Lee
Ran my Powersofts all weekend in 97 degree heat for 15 hours each at 2 OHMS on Subs and not even a hiccup
  • Old enough to know better
  • Audio Plumber
« Reply #5 on: July 28, 2015, 12:28:02 pm »
IIRC Powersoft recommends no space between amps.
Page created in 0.057 seconds with 22 queries.
