Author Topic: 4mic + 4line x 4 zone mixer  (Read 2735 times)
Ryan McLeod
« on: May 01, 2015, 07:38:50 PM »
I'm stumped.
Looking to solve a unique install project that requires:
4xMic input
4xSteteo line input
4xZone output
And the kicker - each zone must be able to get any combo of inputs (and must be able to have a stereo line AND a mic per output.
Must be simple to use.
A Cloud Z4 MK3 would be ideal if it had 4 mic ins.
Any ideas?
Lee Douglas
  • 47.662615, -116.756954
Re: 4mic + 4line x 4 zone mixer
« Reply #1 on: May 01, 2015, 10:31:02 PM »
I'd probably use a BSS Blu-100 for that application.  Four more outputs than you're asking for, but nothing wrong with spare outputs.
Added: Unless you need stereo outputs, then it's sized exactly the way you need it.
« Last Edit: May 02, 2015, 09:45:27 AM by Lee Douglas »
This space for rent
Craig Hauber
« Reply #2 on: May 02, 2015, 02:06:43 AM »
I'm stumped.
4xMic input
4xSteteo line input
4xZone output
Any ideas?
dbx Zonepro 1260 (PC, front panel controllable or wall controls)
or
Ashly 24.24m with 2 input expansion cards (PC or wall controls only)
Craig Hauber
Mondak Sound Design
-Live PA
-Installs
-Theatre
Cailen Waddell
« Reply #3 on: May 02, 2015, 09:33:11 AM »
Yamaha mtx5d
Jason Lavoie
« Reply #4 on: May 02, 2015, 08:58:38 PM »
I'm stumped.
4xMic input
4xSteteo line input
4xZone output
Any ideas?
http://www.symetrix.co/products/fixed-architecture-standalone-dsp/#zone-mix-761
4 mic ins, lots of unbalanced line ins.
Or did you need 4 mic ins plus a dedicated mic input for each output?
in that case I would go to a solus16 http://www.symetrix.co/products/open-architecture-standalone-dsp/#solus
16x8 program it however you want.
both units can be controlled with the ARC-2 controller for easy UI, plus iphone or PC control
Jason
Steven Barnes
    • SBTS Inc.
« Reply #5 on: May 03, 2015, 01:42:09 AM »
I'm stumped.
4xMic input
4xSteteo line input
4xZone output
Any ideas?
Ashly ne24.24m will do this, full retail on an 8x4 system is roughly $1700. All of there input cards have (4) mic pres, so they will accept mic or line level inputs.
http://www.ashly.com/products/protea-dsp-matrix-processors.php
Audio Engineering, Design, Consulting
SBTS Inc.
www.sbts-inc.com
Scott Carneval
    • Cenero Audio Visual
« Reply #6 on: May 05, 2015, 12:32:56 PM »
I'm stumped.
4xMic input
4xSteteo line input
4xZone output
Any ideas?
Do the stereo line inputs need to be balanced?
If not, the dbx ZonePro 1260m would work.  It has 6 mic/line balanced inputs and 4 stereo unbalanced inputs.
Or the Ashly PEMA4125 has 8 inputs, each of which is balanced mic/line OR stereo unbalanced.  As an added bonus, the 4 outputs are 125 watt amplified, and can be had in 70v as well.  Or you can use the line outputs if you don't want/need the amplifier.
Kevin Bull
« Reply #7 on: May 05, 2015, 03:06:00 PM »
Oops
« Last Edit: May 05, 2015, 03:15:48 PM by Kevin Bull »
Page created in 0.063 seconds with 23 queries.
