Pages: [1] 2 3  All   Go Down
Author Topic: 1970s HH amplifiers brought back to life.  (Read 12680 times)
Steve M Smith
  • Isle of Wight - England
« on: April 20, 2015, 05:37:19 PM »
In the UK in the mid to late 1970s, HH was the king of the pub band PA world.
A couple of weeks ago a friend asked me to have a look at two of his amplifiers which he bought around 1976.
One is a five channel mixer amplifier and the other is a slave amplifier.  Both are rated at 100 watts and have two 2N3055 transistors in the output stage. Quite a basic design.  HH together with Carlsbro had the majority of the market at that time but by the early 1980s we had been invaded by Peavey and pub bands started buying their superior designs such as the XR500 and XR600.
They didn't need a lot to get working again.  There were a couple of loose crimp terminals on a bridge rectifier and a few wires which needed re-soldering... and a lot of contact cleaner sprayed into the pots.
Behind the front panels of these amplifiers, there is an electroluminescent panel - so when the power is on, all of the panel lettering glows bright green.  The one on the mixer amp doesn't work any more but the slave one sort of works.  It's a bit patchy.
is what they looked like when new:
« Last Edit: April 27, 2015, 09:55:23 AM by Steve M Smith »
Guy Graham
Re: 1970s HH amplifiers brought back to life.
« Reply #1 on: April 27, 2015, 09:33:00 AM »
Beautiful, thanks for posting that!
The backlit front panel is something I haven't seen for maybe 20 years. It really brought back some warm memories of gigging as a youngster.
I noticed HH are making a limited range of equipment again. However nothing on their current site is pretty in the same way as classics like the IC100 unfortunately.
« Reply #2 on: April 27, 2015, 12:10:18 PM »
Both are rated at 100 watts and have two 2N3055 transistors in the output stage. Quite a basic design. .[/img]
100 watts out of 2 3055s is really pushing it.  4 yes-but 2?
But I guess it depends on "how you measure the watts"----------
There were a lot of products back then that liked to use "peak watts", "instantaneous peak" etc to appear louder than they actually were.
Of course the power supply voltage would be the BIG KEY to how much power it "could" possibly produce.  At least in terms of voltage swing.
Steve M Smith
« Reply #3 on: April 27, 2015, 06:34:57 PM »
Looking at this circuit: http://s652.photobucket.com/user/kvimbo/media/temp/HH_S130.jpg.html?t=126736549 it would appear to be a pair of 2N3773s.  I was sure they were 2N3055s.
Anyway, next up on the repair bench is an old Marshall JTM45.  One of the early ones with a hand bent aluminium chassis.
Steve.
Bob Leonard
  • Boston, MA USA
« Reply #4 on: May 04, 2015, 09:16:57 PM »
The 3055 is one of those three legged dummies that is practically indestructible, but I agree 100 watts is pushing hard. Might work if the heat sink was a Maytag freezer.
BOSTON STRONG........
Proud Vietnam Veteran
Peter Morris
« Reply #5 on: May 17, 2015, 02:41:15 AM »
The HH amp should have 2N3773's in it - the voltage rating of the 2N3055 is not high enough to give an acceptable SOA
http://www.onsemi.com/pub_link/Collateral/2N3773-D.PDF
oops sorry Steve missed your post.
« Reply #6 on: May 17, 2015, 10:10:12 AM »
Yup, the 3055s were hard to kill but slower than dirt***... The 2N3773 was a faster part so a better choice for audio amps, but a single pair will still be heat sink limited for output power (150W per device would require being heat sunk to an ice berg). My personal DIY amp I built back in the early '70s used several 2N3773s in parallel to make 250W @8 ohm (a lot of power for back then).
You will recognize the all too common quasi-complementary output stage, probably lifted from some manufacturer's application note. The PNP power devices of the day were not up to the task so a small PNP in front of another power NPN handled the PNP side of the signal swing.
 *** ironically perhaps, the original (slow) 2n3055 have become collectors items for audio-phools trying to replicate the exact sound of old legacy products that used them as line driver buffers and the like. Device manufacturers probably couldn't make one that slow now if they tried, and they aren't trying. The 2n3055 was so ubiquitous in designs that several versions of them came out trying to hold on to all those design-ins.
« Reply #7 on: May 17, 2015, 10:58:47 AM »
And when they listen to the different amps they can hear a difference-so somewhere in their minds that makes it "better" SIMPLY because it is different-NOT better or more accurate-but "different".
And that is all that matters to some people-------------  They like the fact that they can hear a difference
Steve M Smith
« Reply #8 on: May 17, 2015, 11:21:41 AM »
There is nothing on those amplifiers which you could call a heatsink.  Just the metal case.  I wouldn't want to run them at 100 watts for too long!
Steve.
« Reply #9 on: May 17, 2015, 01:47:44 PM »
An unfortunate reality when selling expensive snake oil is it helps to sound different, when you are arguing how much better you are.
Modern gear that generally sounds more alike than different tends to favor value manufacturing.
Pages: [1] 2 3  All   Go Up
Page created in 0.051 seconds with 24 queries.
