Author Topic: DC area: Amps, speakers, GEQs, snake, Speakon cables, 4U Rack case  (Read 1701 times)
Gordon Waugh
My church purchased a bunch of new audio equipment. I need to sell the following equipment. I am in Woodbridge, Virginia, which is near Potomac Mills Mall next to Interstate 95. It is in the Washington, DC area.
Equipment must be picked up, or I can deliver it with my minivan if you are close or are purchasing several pieces.
Power Amplifiers:
- Peavey pv-2600 540 w per channel rms at 8 ohms. Speakon and XLR connectors. $200.
- Crown ce 2000 400 w per channel at 8 ohms. Speakon and XLR connectors. $150
- Crown power base-1 200 w rms per channel at 8 ohms. Binding post and TRS connectors. $100.
Graphic Equalizers:
- 2 x 2-channel 15-band graphic equalizer: Rane ge215. $100 each.
- 2-channel 31-band graphic equalizer: dbx 2231 with limiter. $200
Power conditioner:
- RackRider RR-15 power conditioner. Third prong on the power cord has been removed (by some knucklehead) $35.
Speakers:
- 2 x Proshow local house brand 15” 3-way passive speakers with Beyma drivers.  Speakon jacks. $500 for the pair.
- 2 x Community MVP36 15” 2-way speakers. Phono (TS) jacks. Can be used as a wedge monitor. $150 each.
200 w continuous. 60-15k +-5db.
http://www.fullcompass.com/common/files/2817-MVP36%20Community%20specs.pdf
- 2 x Proshow local house brand 12" 2-way passive coax wedges. Speakon jacks. Beyma 12cx coax driver. $100 each.
Cables:
- 6 x 2-wire speaker cables with Speakon connectors.  50 feet each.  $90 for all 6 cables.
- Snake: whirlwind 24x4 100'. $250.
Rack case - 4U size:
- RoadReady case RRM4UMKII. Never used (I think). $150.
Best way to contact me is: gordonwwaugh at gmail.com.
Gordon Waugh
« on: April 06, 2015, 12:15:24 am »
Page created in 0.052 seconds with 22 queries.
