Author Topic: XLR to 1/4" adaptor  (Read 2812 times)
Travis Dean TenKley
XLR to 1/4" adaptor
« on: April 02, 2015, 12:24:19 am »
I recently purchased a new snake.  It has xlr returns instead of 1/4" that i'm used to.  My board has 1/4" sends.  I've seen adaptors from nuetrik but it's asking me if I need "wired" or "unwired", what does this mean and which do I need just for the aux sends on my board?
« Last Edit: April 02, 2015, 12:28:58 am by Travis Dean »
John L Nobile
Re: XLR to 1/4" adaptor
« Reply #1 on: April 02, 2015, 12:49:49 am »
More info. What board are you using and are the aux outs balanced or unbalanced?
Travis Dean TenKley
« Reply #2 on: April 02, 2015, 08:20:57 am »
It's a A&H Mix Wiz.  The sends are mono.  Just need to know the difference between "wired" and "unwired".
g'bye, Dick Rees
  • Duluth
« Reply #3 on: April 02, 2015, 08:29:34 am »
Wired:
http://www.audiopile.net/adapter-and-insert-cables
Using barrel adapters willtorque on the board jacks and accelerate wear.  Using the wired adapters will stress the connection less.
For me, barrel adapters are to be avoided.
Nick Enright
  • Detroit, MI
« Reply #4 on: April 02, 2015, 09:30:18 am »
Go Here and Read:
http://www.rane.com/note110.html
Buy your own parts and solder your own.
www.partsexpress.com
Nick Enright
Owner / Engineer
Lyve Productions
Detroit, MI
Travis Dean TenKley
« Reply #5 on: April 02, 2015, 09:39:28 am »
Wired:
So, with these I don't need to worry about "wired" or "unwired", just get the correct balanced adaptor and add it to my snake ends?
Steve M Smith
  • Isle of Wight - England
« Reply #6 on: April 02, 2015, 09:51:16 am »
Wired refers to the fact that there is a flexible bit of wire between the two end connectors. With the barrel connectors, the potential extra leverage can put strain on the socket or the adaptor itself leading to damage.
Get balanced XLR to jack connectors and if you use them on unbalanced outputs, they will still work.
Steve.
Page created in 0.031 seconds with 22 queries.
