Pages: 1 2 [3]  All   Go Down
Author Topic: Laptop power supply causing hum through dj rig  (Read 11326 times)
Scott Carneval
    • Cenero Audio Visual
Re: Laptop power supply causing hum through dj rig
« Reply #20 on: June 28, 2016, 10:59:27 am »
All MacBook Pros that I've seen (I have 2, employees have them, many friends, colleagues, and clients have them) have 3 prong connectors. Never once had a buzz from any of them.
I think it's more to do with the specific power supply or laptop and not just the 'presence of a 3-prong adapter'.
Question though, I've seen many PC's without a ground prong on their adapter. Are these inherently unsafe, or is there something different about those power supplies?  In other words, why is it unsafe to remove the ground prong from a 3-prong supply when some PC's only come with a 2-prong supply in the first place?
Don T. Williams
    • Q Systems Music & Sound
« Reply #21 on: June 28, 2016, 11:38:47 am »
I've had several laptop noise problems that were cleared up by simply running them on the internal battery power.  One computer with a "short life" weak internal battery had the problem solved by using a 12V alarm system back-up battery wired to the computer's automotive power supply cable in an "emergency".
David Buckley
« Reply #22 on: June 28, 2016, 06:28:48 pm »
Yes, of course it is: many manufacturers of power supplies for laptops carry through the ground from the mains to the negative of the output.  If there isn't an incoming ground then they cant do that.
If there is no ground pin, then the deice being powered must be designed and built to make it incapable of giving someone a shock.  This is most commonly done by making the thing "double insulated", which has the two square boxes symbol.
The other approach is to ground stuff, so if a fault occurs, then then effectively the fault current is shorted to ground causing a fuse to pop.  So, if you chop off the ground pin, there is no safe return path, and under fault conditions, someone can become shocked.
Ray Aberle
    • Kelcema Audio
« Reply #23 on: June 29, 2016, 04:50:58 pm »
OP has not seen fit to reply with requested information in the last 10 weeks. Perhaps just ignoring the problem made it go away...
That's a YEAR and ten weeks... since the thread started in March of last year. :)
-Ray
Kelcema Audio
Pages: 1 2 [3]  All   Go Up
Page created in 0.044 seconds with 24 queries.
