Author Topic: Would this be correct use of a DMX Splitter?  (Read 2059 times)
Tony Rivieras
« on: February 21, 2015, 09:28:33 pm »
Hello All, Firstly i would like to say i am by no means a expert with lighting. My question is, I would like to use a DMX Splitter to go from a center truss to other pieces of truss on the left and right side of the center one. Rather than running a cable to one side and then back over the center one to the other side i was thinking of using a Splitter on the center truss and then the 2 data cables can go directly to the other sides.
is this something that would work?
Look Forward to your replies
Tony Rivieras
Cailen Waddell
Re: Would this be correct use of a DMX Splitter?
« Reply #1 on: February 21, 2015, 11:29:47 pm »
Yes
Keith Broughton
  • Toronto
« Reply #2 on: February 22, 2015, 06:05:34 am »
Tony Rivieras
It will work.
However, you now have an active piece of equipment in the air and if it fails, you are toast.
Another way to do this is home run DMX from each truss to the floor and split in a location where you can trouble shoot, if required.
Jerome Malsack
« Reply #3 on: February 22, 2015, 09:42:54 am »
Also dont forget the terminators.  One one each split ?
Cailen Waddell
« Reply #4 on: February 22, 2015, 11:11:50 am »
Meh - terminators are over rated.  I have been toured all over the world, and run hundreds dmx devices in the various theaters I manage.  I've never had a problem that a terminator fixed.  If you use fully dmx complaint fixtures and use quality dmx cable, you should be fine.
Josh Daws
« Reply #5 on: February 22, 2015, 02:51:51 pm »
agreed, and not to mention most splitters have a terminate button on it.
Tony Rivieras
« Reply #6 on: February 22, 2015, 03:34:19 pm »
It will work.
Having to run it back down to the floor would be too many cables, as it is since the splitters on the truss i have to run a
Edison extension cable to power to it. As for the termination i was planning to use a terminator on each split. I'm sure it wont hurt.
Thank you
Tony
Page created in 0.05 seconds with 19 queries.
