Pages: 1 ... 35 36 [37] 38 39 ... 55   Go Down
Author Topic: brain storm an optimal human safety system for back line  (Read 109237 times)
Stephen Swaffer
Re: brain storm an optimal human safety system for back line
« Reply #360 on: October 08, 2015, 10:38:25 pm »
From my experience most homes that have 1-15 receptacles still have 2 wire either  K & T or  Romex.  Bootleg grounds are common, as is reverse polarity. As Mike has repeatedly warned this can be a dangerous combination.
The other thing that might be creating odd readings on JR,s beta device could be the lack of a grounding electrode and or bonding.  This could cause the neutral to appear to be at any potential with respect to ground and other metal objects/systems.  Not sure how a body's capacitance would play out as far as grounding if the only true reference is hundreds of feet away?
Steve Swaffer
« Reply #361 on: October 08, 2015, 11:26:13 pm »
The secret sauce for my tester is to use the human body as a local 0V reference. Of course nothing is exactly 0V but close enough.(+/-10V?) I buffer that human voltage reference with a high input impedance MOSFET.
AFAIK the design is getting mature and works as expected everywhere I have tested it so far (perhaps a half dozen different buildings).
The results Mark reported made me concerned the prototype was faulty... (hand soldered by an old man), but when I got it back it worked exactly like it did when it left.
I'll get him a second generation prototype that has some minor improvements, less spurious leakages..more robust ground present indication etc. If he still gets spurious results I will ask him to do more testing of his power.
I fell like this tester design is getting pretty close to ready for prime time... The final resistor values I need to finish tweaking this are ordered and shipped so just a matter of days.  ;D
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #362 on: October 08, 2015, 11:28:53 pm »
Neat!
I want one.
Mark Cadwallader
  • Helena, Montana USA
« Reply #363 on: October 09, 2015, 01:11:29 am »
Update:  Follow-up testing (using a Fluke 323 clamp meter w/probes and Fluke 1AC-C NCVT) show that the NEMA 5-15 receptacles do NOT appear to have a RPBG condition. Tested as per Mike's link (above).
I'll repeat the tests this weekend to check my work.  I'll also check using two other NCVTs I have, and a different DMM, and report back.
Edit:  Pending additional testing, the above results should probably be qualified as "initial" or "preliminary". I think that I know how to conduct the testing, but I don't want to assume too much, or rely on a single result with only one set of test instruments.
« Last Edit: October 09, 2015, 01:25:34 am by Mark Cadwallader »
« Reply #364 on: October 09, 2015, 09:48:53 am »
I also like neon lamp probes, or using a VOM with the body serving as the ground reference but BE CAREFUL to make sure VOM is in AC Volts scale, since using ohms or current scale could deliver a dangerous shock hazard.
My NCVT is useless for determining outlet wiring (too sensitive). It goes off when I get anywhere near my bench with it.
PS: Using my trusty old ratshack VOM, and JR_as_ground I measure 50 VAC on line, 11 VAC on neutral, and 1 VAC on an open floating ground. Not very precise but good enough to differentiate line from neutral. Just be careful when probing hot power circuits.
Jonathan Johnson
« Reply #365 on: October 09, 2015, 10:42:17 am »
Sounds like a test for Darwin Award nominees.
frank kayser
« Reply #366 on: October 09, 2015, 10:58:13 am »
Neat!
I want one.
I'm with you!  Been a big cheerleader of this project from the start - and am thrilled that JR is in discussions with a manufacturer.
One way or the other, I REALLY want one, too!
frnk
« Reply #367 on: October 09, 2015, 12:17:13 pm »
Got my new resistors in today, so this weekend I should be able to finalize this.
Slow and steady but moving forward...
Mike Sokol
« Reply #368 on: October 09, 2015, 12:44:08 pm »
The  Gold Standard test is to run a long wire to the frame-ground of the service panel, and use a low-impedance meter between it and the Line, Neutral, and EGC-Ground contacts in each receptacle. I also do some loading between the various lines with a 100-watt bulb to make sure there's no open line that's being "phantom" energized via capacitive coupling.
BTW: If you use enough of a load (I have a little 600/1,200 watt space heater for this) you can also figure out if there's a swapped neutral and ground in an outlet. While a swapped N-G won't show up with any standard (unloaded) test, it does create all sorts of ground loop hum in sound systems. I've found swapped N-G lines in several church installs during the last two years of looking, but I was only looking because of a reported ground loop hum. It may be fairly common in new installs done by non-electricians. Another fail that a 3-light tester won't find, and JR's gadget won't find it either.
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
« Reply #369 on: October 09, 2015, 01:39:53 pm »
Yup I only confirm that a ground connection is present and then test for hazardous voltages. My tester even says RPBG ground is present,,, but it also warns that the safety ground happens to be hot.  >:( (danger Will Robinson)
I believe I could come up with a microprocessor based outlet tester that could parse out ground quality too, but first things first. A simple outlet tester that accurately reports hazardous voltages seems a useful start and the far more important need.
Pages: 1 ... 35 36 [37] 38 39 ... 55   Go Up
Page created in 0.071 seconds with 23 queries.
