Pages: 1 2 [3] 4 5   Go Down
Author Topic: Stage Power Drops  (Read 11927 times)
frank kayser
Re: Stage Power Drops
« Reply #20 on: October 20, 2014, 02:20:10 pm »
"Ouch" I'm trying.  :'(
Is it just the knock outs that make these a no no, or is there something else too?
Answering that is well above my pay grade.   :-X
I do know about the knockouts from other discussions here, but beyond that, I'm just like you:
Waiting for the Electrician (or someone like him).
We're all learning, and once things are brought to our attention, it takes time (and money) to correct.  If the wiring is good, and the boxes are in good condition, you may not meet code with the inspector, but they SHOULDN'T cause you any problems, either. (IANAL, nor am I an electrician) YMMV.
frank
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #21 on: October 20, 2014, 02:25:31 pm »
The boxes are for indoor permanent wiring only.
Use outdoor boxes and proper strain relief on the wires. While not actually code compliant, I believe most folk would accept them in a weekend warrior setting.
I have two sets of boxes. One with metal outdoor boxes and one with plastic outdoor boxes. Both have Powercon in and out on them. I just place em on the stage where I want them and hook em up. I do have one box with a GFI outlet in it and it protects the output connector too. I use it for the stage stringer.
Jamin Lynch
  • Corpus Christi, TX.
« Reply #22 on: October 20, 2014, 03:03:25 pm »
frank
Trying to make my "un-safe" boxes a little more safe until I can get the "safe" boxes I really want.
Ray Aberle
    • Kelcema Audio
« Reply #23 on: October 20, 2014, 03:08:14 pm »
Which is a good thing! :)
Another issue with the indoor boxes is that you can see they have holes for nailing through-- those holes can allow water inside the box. Or dirt. Or worms. All of that can cause drama.
Kelcema Audio
Frank Koenig
« Reply #24 on: October 20, 2014, 03:09:32 pm »
I saw just this arrangement used for drops from the ceiling to work benches in a brand spanking new industrial lab. They used regular, cast aluminum "wet locations" boxes, Kellems-style braided strain reliefs, and indoor Nylon covers. It apparently passed inspection in Burlingame, California. --Frank
Stephen Swaffer
« Reply #25 on: October 20, 2014, 04:43:05 pm »
I have used the same and been accepted by inspectors.  With the proper strain relief this things are safer and more durable than an extension cord, IMO.
One thing that can't be seen in the photos-and would be expected/inspected by most inspectors is a bonding jumper to the box from the  EGC. A lot of guys (usually non electricians) let the receptacle ground the box or vice versa.  Really doesn't take much to put a grounding jumper to each receptacle one to the box and tie them all together-remember this is about safety-not convenience.
Steve Swaffer
jasonfinnigan
« Reply #26 on: October 20, 2014, 04:51:35 pm »
Yep. Wet location boxes that use threaded holes instead of knock outs pass here as well for portable use. I don't use them but I can see them being useful if I don't have my quad box stage stringers. Use a plastic strain releif that screws on or one of those steel mesh strain reliefs.
« Last Edit: October 20, 2014, 04:53:37 pm by jasonfinnigan »
« Reply #27 on: October 20, 2014, 06:25:21 pm »
They are ugly.  Look like they came out my wood shop in high school circa 1970
Ray Aberle
    • Kelcema Audio
« Reply #28 on: October 20, 2014, 06:48:55 pm »
I think he was asking "is there something else LEGALLY/in the electrical code that would make these improper to use?" as opposed to any aesthetic point of view.
Kelcema Audio
Jonathan Johnson
« Reply #29 on: October 20, 2014, 10:21:50 pm »
The only way to know for sure is to read the minutes of the NFPA 70 committee that adopted that section of code, and that may not even be sufficient; a transcript would give the best insight.
If a knockout gets knocked while the devices are energized, it could come in contact with a terminal screw, causing a small arc flash.
The mounting holes could permit insect, dust, and moisture entry.
On the other hand, most inspectors allow the permanent install of these boxes in exposed locations, so the primary concern probably is the higher likelihood of damage when used temporarily.
Pages: 1 2 [3] 4 5   Go Up
Page created in 0.054 seconds with 22 queries.
