Author Topic: Best clamp on ammeter for the buck  (Read 2667 times)
(Brian) Frost
« on: October 14, 2014, 04:28:58 am »
Looking for something that will be cost effective and do both ac and dc.  Im not going to use it hard but I would like it to not break either.  I dont know if this needs to cost $40 or $300... whats my biggest bang for the buck.
Use: double check system pull during setup for generator loads, install work etc
Stephen Swaffer
Re: Best clamp on ammeter for the buck
« Reply #1 on: October 14, 2014, 10:37:12 am »
Check out the Klein CL2000-bought one about a year ago and am very impressed with quality.  I was concerned about durability-I do a lot of industrial/ag work so its not always easy to treat a meter with TLC.  Will measure 400 amps ac/dc, has a built in NCTV and magnets to hold the meter so you can use the probes.  Iirc cost about $160.
Steve Swaffer
Kyle Van Sandt
« Reply #2 on: October 14, 2014, 12:21:42 pm »
http://www.mcmelectronics.com/product/TENMA-72-7226-/72-7226
My wife's is going on 5 years.  My old Tenma meter is going on 15 years.  Can't go wrong.
Kyle Van Sandt
Production Coordinator
The Egg, Albany, NY
vansandtdesigns.com
Jeff Robinson
  • Kansas City, MO
« Reply #3 on: October 14, 2014, 12:23:51 pm »
Extech (FLIR) MA640 is also ~$160, 600A AC/DC true RMS, NCVD, resistance, capacitance, temperature and a couple other functions.
http://www.extech.com/instruments/product.asp?catid=26&prodid=517
Disclaimer, in stock at my day job (electrical distributor).
Jeff Robinson
Excerpt from Shelley's 'Ode to a Skylark':
__________________________________
Hail to thee, blithe Spirit!
Bird thou never wert
That from Heaven, or near it
Pourest thy full heart
In profuse strains of unpremeditated art
Such harmonious madness
From my lips would flow
The world should listen then, as I am listening now!
Stephen Swaffer
« Reply #4 on: October 14, 2014, 01:52:17 pm »
I have always liked Tenma-for the money they make good equipment-do take into consideration overvoltage protection.  The Tenma is rated at Cat III 300 volts, Klein and (I presume the Extech) Cat III 600 volts.  So, if you never deal with 480 VAC, the Tenma would be fine-just make sure to keep that spec in mind as well.  It is often overlooked, but important!
Steve Swaffer
Jeff Bankston
« Reply #5 on: October 14, 2014, 03:27:04 pm »
i have a Fluke 336
Page created in 0.025 seconds with 24 queries.
