Author Topic: DSP Recommendations  (Read 4627 times)
Mario Pollio
DSP Recommendations
« on: September 22, 2014, 08:16:30 pm »
Now that I learned a bit about DSP's, I'm looking for a recommendation. I'm a mobile DJ that currently uses JBL PRX speakers and will be adding Danley TH118's and SM80's powered by crown I-tech amps to the inventory for larger, higher paying jobs (hopefully sooner rather than later). I'm looking for a DSP that I can use for either one of these set ups. My budget is in the $500 dollar ballpark but am a bit flexible if there is something in the range that is worth it. What DSP would you guys recommend for my use and why? The system would range form a pair of PRX615m's (smallest) to PRX615m's with 2 PRX618s-XLF's, to an absolute maximum of 4 TH118's and 2 SM80's (largest sound system).
Caleb Dueck
Re: DSP Recommendations
« Reply #1 on: September 22, 2014, 08:27:37 pm »
Ashly 3.6SP is close to budget new.  You need to look used, or up the budget.  If you have a laptop, a Symetrix Jupiter 4 or 8 would be great.
« Reply #2 on: September 22, 2014, 08:31:58 pm »
As a general idea you need a 4x8 (4 in 8 out) DSP
The way I figure is as follows.
Left and right main inputs and biamped PA.  It doesn't matter how many subs you add-they will all be off of the same DSP ouptut.
That is 2 in and 4 out. (hi and low for each left and right)
DJ monitors  left and right in and biamped as well.
You might start with full range monitors-so that would be 2 out-but plan on 4 outputs (stereo lo and hi) so you don't have to "redo" your system if you upgrade.
I am not aware of a 4x8 at that price point new-but you might can find some used.
There is nothing special needed for the Danley speakers-so pretty much any DSP would work as long as it has the basic functions.
Mario Pollio
« Reply #3 on: September 22, 2014, 08:34:40 pm »
Yes, I have a laptop. You would recommend the symmetrix Jupiter's over the Ashly 3.6SP then? I'm guessing the Driverack units are overhyped
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #4 on: September 22, 2014, 08:35:44 pm »
Remember that iTech's already have a decent internal DSP. Any DSP you buy can likly be sold if you go with an amp that has on board DSP.  You really should go with an amp that has on board DSP.
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Mario Pollio
« Reply #5 on: September 22, 2014, 08:36:59 pm »
Which would be the closest to that price point that you would recommend? I haven't seen that many DSP's with that many inputs and outputs.
« Last Edit: September 22, 2014, 09:47:15 pm by Mario Pollio »
Mario Pollio
« Reply #6 on: September 22, 2014, 09:48:48 pm »
So with an amp with the onboard DSP, I wouldn't even have to buy an external DSP? What is the DSP in the I-tech amps limited to? I know with something like a driverack, it also comes with a feedback eliminator, which is nice.
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #7 on: September 23, 2014, 12:02:04 am »
With the speakers you are looking at, there is no need for any external processor if you are using iTechs.  The amps can handle it all, EQ, crossover, delay, limiting. If you need a feedback eliminator, you are probably doing something wrong.
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Samuel Rees
  • Washington, D.C.
« Reply #8 on: September 23, 2014, 12:28:01 am »
Agreed. Just get iTech for your Danley. If you're just stepping out of PRX world, I imagine you'll have enough on your plate learning to use the advanced iTech DSP.
Mario Pollio
« Reply #9 on: September 23, 2014, 06:37:52 am »
Thanks for the advice. I definitely have a lot of learning to do.
I don't really need a feedback eliminator. I have a basic wireless mic system (Shure BLX24 with an SM58) and never had feedback issues. I had a Sennheiser mic that retails at about twice the price that had more feedback issues. I guess in some cases, simpler is better.
