Author Topic: Blacklight Fixtures  (Read 5690 times)
Steve Alves
  • South Florida
    • South Florida Sound
Blacklight Fixtures
« on: September 10, 2014, 09:50:23 am »
Need to cover an area about 100' x 100' outdoors at night (dark area) with blacklight. I figure I will need to use multiple fixtures around the area facing in. Looking at the following two products, which one will give me a better effect. Event participants will be wearing UV bracelets and glow paint will be in use.
http://www.amazon.com/Eliminator-Lighting-EBK-400-Black-Fixture/dp/B000GAVBI4
http://www.amazon.com/Chauvet-Shadow-Three-Channel-DMX-512-Blacklight/dp/B000LNHHMA/ref=sr_1_1?ie=UTF8&qid=1410356981&sr=8-1&keywords=chauvet+led+shadow
Or if someone has a better product idea.
Thanks
Steve
Steven Alves
South Florida Sound, Fort Lauderdale, FL
www.southfloridasound.com
John Fruits
Re: Blacklight Fixtures
« Reply #1 on: September 10, 2014, 10:58:22 am »
The lamp based usually are more UV only while the LED units are wider spectrum so more blue light.  Another unit to look at is the AmericanDJ Cob Cannon, lots of positive comments on it.
http://www.americandj.com/ProductDetails.aspx?ItemNumber=2245&MainId=2&Category=Black_Lights
If this is a one time thing, how about just renting some WildfireFX or Altman units.
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
Milt Hathaway
    • http://www.fitzcosound.com
« Reply #2 on: September 10, 2014, 10:58:46 am »
In my experience the UV LED lights still emit too much visible blue light.
I have heard good things about American DJ's UV Cannon: http://www.americandj.com/ProductDetails.aspx?ItemNumber=1241&MainId=2&Category=Black_Lights
It appears to use the same lamp as the Eliminator you linked, but the optics of the ADJ might be better.
Milt
FitzCo Sound, Inc.
Midland, TX
Milt Hathaway
« Reply #3 on: September 10, 2014, 10:59:23 am »
The COB Cannon is still LED, though.
Milt
FitzCo Sound, Inc.
Midland, TX
Steve Alves
  • South Florida
« Reply #4 on: September 10, 2014, 11:06:51 am »
I saw that one and looked to see that it used the same bulb. It appears to be more of a spot compared to the Eliminator which is a wash.
Steven Alves
Len Zenith Jr
« Reply #5 on: September 10, 2014, 12:54:36 pm »
Those 400w UV HID bulbs are very, very, very inefficient at producing UV light, you will be disappointed in the output for the amount of power they consume. A small florescent fixture will output much more UV light than those. The 100w elation UV washes are very good units with output magnitudes higher than the HID units. The ADJ version of the same can be found here. Regarding LED's, the visible light output of UV LED's may or may not be desirable depending on how dark you want the area to be. Dark may be nice for a stage or a display, but for patrons running around a bit of wash can prevent trips/falls, etc.
Steve Alves
  • South Florida
« Reply #6 on: September 10, 2014, 03:03:33 pm »
Which one of the above has the higher output?
Steven Alves
Len Zenith Jr
« Reply #7 on: September 10, 2014, 03:34:47 pm »
The ADJ HP panel has a bit more output than the Elation UV wash and 400w HID combined however the Elation is still a very good unit.
Paul G. OBrien
« Reply #8 on: September 11, 2014, 08:40:58 pm »
http://www.amazon.com/Chauvet-Shadow-Three-Channel-DMX-512-Blacklight/dp/B000LNHHMA/ref=sr_1_1?ie=UTF8&qid=1410356981&sr=8-1&keywords=chauvet+led+shadow [/quote]
These two fixtures aren't even in the same ballpark, you might "cover" your area with 6-8 of the Eliminators but you would need hundreds of those LED panels to do it. The ADJ UV canon also produces a lot of output(I won't argue how much of it is actual UV) but note that these are very big fixtures.. about the size of a 10 gallon bucket.
Steve Alves
  • South Florida
Steven Alves
« Reply #9 on: September 11, 2014, 10:17:05 pm »
Page created in 0.151 seconds with 23 queries.
