Author Topic: Church install advice  (Read 3372 times)
Jean-Pierre Coetzee
  • Gauteng, South Africa
Re: Church install advice
« Reply #10 on: September 11, 2014, 06:20:30 am »
What is the ceiling hight of this room, we have a similar room but the ceiling is just over 3m so it is nearly impossible to get proper sound in there while keeping sight lines on stage in mind. This is also a very wide room that isn't very deep. I haven't looked much at the speakers mentioned but I know that you will be much better of getting a contractor in to recommend an install then to demo that install and see if you are happy with it than for you to get random advice of a sound forum when nobody on that forum has even seen the room.
Could you also list at least a rough location of where you are, maybe somebody is close to you.
What is wrong with the system you currently have deployed that it needs to be replaced, if there are damaged elements but it serves it's purpose well enough then I would rather recommend doing some maintenance to get it back to where it should be and then leaving the system as is.
You also mentioned sound treatment, this alone could make the system overall sound better and I would recommend you do that first before you consider an upgrade/replacement, especially if the room acoustics are as bad as what you make them out to be.
Audio Technician
Word & Life Church
- Ivan Beaver
Jean-Pierre Coetzee
« Reply #11 on: September 11, 2014, 06:50:33 am »
Quote
We wont be running the system at rock concert levels right off the bat(if ever), though for certain events, that might be good to have. We've got acoustic drums, that we are planning on partially enclosing and mic'ing. Currently the electric guitar is going direct through a POD, and acoustic guitars are going direct as well. The bass is the only amp currently on stage but mostly because our current system cant handle that spectrum of sound.
Are you saying that the Nexo system just doesnt have the power to handle a full band? Our room is fairly wide(wider than it is deep)95' long and 43' to the back wall from the front of the stage. The proposal is for 4 PS10s across the front of the stage.
I would like to comment on this in that 4 across the front of the stage will give you some phasing which will definitely cause issues with uniformity, how tall is the roof? It could be possible to just use 2 hangs of the right speakers as well depending on the room. Are there isle where it would be best to have nulls which you will then be able to have a more zoned approach, there doesn't need to be decent coverage in isle since I'm pretty sure that your local law much like ours makes it illegal to have the isle blocked by people/things.
Audio Technician
Word & Life Church
- Ivan Beaver
« Reply #12 on: September 11, 2014, 07:51:03 am »
We are currently running our services at around 93dB, A weighted, but thats with 25 yr old equipment and a very reverberant room. We dont necessarily need something that is going to shake the foundations, but i'd like something that can handle the full spectrum of sound we would be putting through it. Currently we have drums, keys, bass, 2 acoustics, and an electric guitar. We also are going to be playing with tracks, so its going to be quite a lot of sound coming out.
So what is the question?  Are you happy with the levels you are getting now-but just not getting enough low freq response?
If so, then just add some subs.
Is it the sound quality of the current system?
What IS the current system.  How do you know that either of the proposals will be a step up?  We don't where you are starting from--------------
In another post you said you don't need "concert level but it would be nice to have".
How much money do you have for this?  You do realize that "concert level" is a good 10dB or more higher than your current level.
That comes at a PRICE $$$$  Are you willing to spend it?
That makes a HUGE difference in the way somebody proceeds with recommendations.
Somebody could propose a system that WILL give you concert level, but will lose out because of the price.  They cold provide you with a less expensive system that will get the job done-and compare price wise with the other proposals.
You HAVE to compare apples to apples.
Maybe you need a full 1 ton pickup once or twice a year.  So is that what you buy (and pay for), when what you really need is a mini pickup for most of your usages?
Less up front costs etc.  And you can always rent when needed.
FIRST you have to ACCURATELY define the goals of the system and the REAL NEEDS, THEN you start to look at what will satisfy them.
If you don't accurately define the "design goals", then how will you know if they are being meet?
Robert Healey
« Reply #13 on: September 11, 2014, 10:50:29 am »
Sorry for the confusion. its my first time posting on this forum and wasn't sure where to post.
The room is 95 feet across and 43 feet from the front of the stage to the back wall. We are currently running our services at around 93dB, A weighted, but thats with 25 yr old equipment and a very reverberant room. We dont necessarily need something that is going to shake the foundations, but i'd like something that can handle the full spectrum of sound we would be putting through it. Currently we have drums, keys, bass, 2 acoustics, and an electric guitar. We also are going to be playing with tracks, so its going to be quite a lot of sound coming out.
I want to know which, if any, of these proposals will be best suited for our space. I realize the speakers are just a small part of it, but I would say everything else is about equal otherwise.
I think you're getting vague answers because there are so many other factors than just the model numbers of the speakers. Sound systems are just that - systems. The entire system design has an important role in the functionality. Furthermore, without fairly detailed architectural plans and sections we aren't qualified to comment on the bids. Both speakers you have listed are professional tools - but not every tool is right for every job. Depending on your circumstances, either would work well. Without being involved in the whole process, we can't give you a straight answer because we have an incomplete idea of your particular circumstances.
There are consultants who would be happy to do a peer reviews of your multiple bids (for a fee) - in fact, many of the people commenting on this thread provide those services. It is more involved process than just looking at the model numbers  - it would be a through review of the contractor's documentation, the modeling used by contractors to lay out the system, and perhaps building their own EASE models if the bidder's are incomplete or suspect. There would be a final recommendation to pick one bid over the other and possibly suggestions for the contractor to incorporate into the design.
