Author Topic: D&B Q-Sub... stacked CSA or end-fire?  (Read 2204 times)
David Pallett
« on: June 23, 2014, 05:37:05 pm »
Just curious as to what's considered the best option when you have three subs a side available.
I've used end-fire successfully on numerous occasions, especially with active subs when delay was available only on the console as opposed to the amp, and been happy with the results.
Just been working as assistant tech to a guy who prefered the d&b 3 sub CSA stack, bottom one forward, middle one backwards, top one forwards.
What's the optimum method assuming there is space available?  I've not had time to model this in array calc yet.
Re: D&B Q-Sub... stacked CSA or end-fire?
« Reply #1 on: June 24, 2014, 08:06:33 am »
It depends on what you need to do for a particular application.
All facing forward will give you the most SPL output and best sound quality.
A endfire or cardioid arrangement will give more cancellation to the rear.  The endfire will give more output and better sound quality than the cardioid-but the cardioid will give better rejection to the rear.
So you need to choose what is best for a particular application.
You DO NOT get the best sound-highest SPL and most rejection from any configuration.
Everything is a compromise-sorry
Page created in 0.023 seconds with 23 queries.
