Author Topic: Grounding info that could save your life.  (Read 9299 times)
Re: Grounding info that could save your life.
« Reply #10 on: July 02, 2014, 10:22:58 am »
I had several Fender amps like this back in the 60's and 70's when I was a long-haired hippie child playing in a band. You would flip the switch back and forth and feel for the position of least shock (no kidding). IIRC my Kustom 100 also had this same sort of switch on the back. NOTHING was grounded in our backline or PA back then and we were always getting some kind of shock. But that was accepted as normal and part of playing "electric" instruments.
OT but really cool were the Red & Blue jeweled power lights on the front of old Kustom amps. They were visually hard to focus on which made them very easy to recognize from the back of the club.
You were supposed to switch it for least audible hum, it wasn't supposed to give you a (dangerous) shock in either position. I am a little surprised that UL blessed the concept. They surely specified the type caps used for that task.
This has been discussed before but you can cap couple the ground inside the guitar to adequately reduce hum while increasing human safety.
Mike Sokol
« Reply #11 on: July 02, 2014, 12:39:27 pm »
Yeah, but I can remember getting shocked a bunch of times. Of course, if the cap shorts out then it's a killer when switched to the (random) line side.
Mike
« Last Edit: July 02, 2014, 12:52:27 pm by Mike Sokol »
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Jeff Bankston
« Reply #12 on: July 02, 2014, 04:19:12 pm »
i'm glad we are having this discussion. i will find out if anyone i know has an old 2 prong cord guitar amp and have them read this. what about 2 prong transistor guitar amps from the late 60's-up ?
« Reply #13 on: July 02, 2014, 05:44:53 pm »
Any UL approved consumer electronic product of recent vintage with 2 wire line cord will have double insulated power transformers and no shock hazard... This is mainly very OLD guitar amps.
Mike Sokol
« Reply #14 on: July 02, 2014, 05:54:29 pm »
Late 60's guitar amps are suspect, especially if they've been ridden hard and put away wet. JR, I have a pretty simple test method for testing potential line-to-chassis leakage on old amps. Should we compare notes before I loose this on the masses?
Mike Sokol
www.NoShockZone.org
« Reply #15 on: July 02, 2014, 06:14:12 pm »
I trust your common sense ....  carry on.
My advice is to remove any such caps and switches and permanently hard wire in a grounded line cord.
End of story...
Page created in 0.031 seconds with 23 queries.
