Author Topic: McCauley M421 VS Danley TH812 Rock Monster  (Read 14436 times)
Kyle_Keating
Re: McCauley M421 VS Danley TH812 Rock Monster
« Reply #10 on: May 26, 2014, 02:30:13 AM »
   Simple Question , Which one wins ? Or mabey not so simple  ;D  Ill get to hear the McCauley next week , 2 of the driven by 2 powersoft K20's in a stadium so should be fun.
Is the M421 an isobaric design? Meaning each pair of 21's are loaded front to back in the same baffle? Or is this a quad loaded horn?
Art Welter
« Reply #11 on: May 26, 2014, 08:27:23 AM »
Kyle,
The M421 is an isobaric tapped horn, photos of the isobaric chamber which contain the drivers loaded front to back are visible in the review linked in post #4.
Art
Kyle_Keating
« Reply #12 on: May 26, 2014, 02:16:47 PM »
Kyle,
Art
Thanks Art, I see it now, the left front drive has been removed in this picture. Is the chamber between the pair of drivers part of a horn or just an isolated volume?  And are the woofer in or out of phase in this alignment?
https://soundforums.net/attachment.php?attachmentid=1579&d=1308795096
« Last Edit: May 27, 2014, 12:17:10 AM by Kyle_Keating »
Art Welter
« Reply #13 on: May 30, 2014, 11:13:29 AM »
The isobaric chamber between the drivers is isolated from the outside atmosphere. The two drivers and the air in the isobaric chamber combine as one driver driving the tapped horn. The two drivers face the same direction and are wired in the same polarity, positive voltage makes both drivers go the same direction.
Kyle_Keating
« Reply #14 on: June 04, 2014, 12:50:33 AM »
Thanks Art
drew gandy
  • Chicago and burbs
« Reply #15 on: June 19, 2014, 12:31:15 AM »
Thanks Art
And to add to Art's calculations comments earlier, isobaric systems tend to use up precious cabinet space (usually in the name of shrinking cabinet size, go figure) with the chamber of air and other parts necessary to fit the pair of drivers together.  That means that the Danley likely has an even greater "total cubic space" advantage than might appear on paper.  But, this is not to say that there aren't other advantages to the isobaric configuration.  McCauley may very well have gone with this configuration because they couldn't find (or manufacture) a single 21" with the parameters they wanted.
Arrogance is usually far worse than ignorance. But every once in awhile they swap places.
Page created in 0.057 seconds with 23 queries.
