Author Topic: A good pro TT  (Read 9908 times)
Gene Flynn
Re: A good pro TT
« Reply #10 on: March 29, 2014, 09:43:40 pm »
I would use the 1200, and build a suspension system for it. feedback is definitely a problem with bass and decks.
Thanks for all the advice.  Much appreciated..
Gene
Tim Padrick
  • Indianapolis
    • T.P. Audio
Re: A good pro TT
« Reply #11 on: March 30, 2014, 02:34:09 am »
For DJ use, a 1200.  You can get one on eBay for $500.
For home use, a Linn Basik, Rega Planar 2, or Rega Planer 3 (all used, of course).
Gene Flynn
Re: A good pro TT
« Reply #12 on: March 30, 2014, 09:02:24 pm »
Linn looks pretty nice, and a huge wooden plinth..  Kinda like the old Duals..  I have a VPI scout for my home system..  Im looking at either the Linn Basik or an old Dual..  Trying to stay below 500..
The hunt is on....  ;D
Thanks
Tim Padrick
  • Indianapolis
    • T.P. Audio
Re: A good pro TT
« Reply #13 on: March 30, 2014, 11:48:31 pm »
Linn for sure.
Stephen Snipes
Re: A good pro TT
« Reply #14 on: March 31, 2014, 09:35:15 am »
Seeing as how I use 1200s I'd say only get them if you're using it to DJ which you're not. It is a good deck overall and reducing vibration is real easy. You can set them on rubber pads which will help absorb a lot off that bass. A quality needle goes a long way too
Jeremy McNichol
Re: A good pro TT
« Reply #15 on: June 23, 2014, 03:35:20 am »
Sooooo. Did you get a TT? If not I'd +100 on the 1200 mkII. The 1200 was originally built as the second from the TOTL for home use, a technicality many "audiophiles" seem to miss. The wow and flutter specs are far below most other decks specs are, they're built like a tank and because of an upsurgance of use for home systems are infinitely upgradable. I recently bought mine used for $175 with an audio technica cart. The most common problem with them is the capacitors which are easily replaced.
Jonathan Race
    • Evolution Mastering
Re: A good pro TT
« Reply #16 on: July 28, 2014, 04:45:14 pm »
Any suggestions for a good pro TT??  It will only be used for playback so no need for anything fancy..
Thanks
+1 on the technics 1200 you can't beat a classic. Although looking around that Pioneer alternative does look rather tempting
Jonathan Race
Online Mastering
Reggie Kendrick
  • Channel Live Productions - raising the bar...
Re: A good pro TT
« Reply #17 on: July 29, 2014, 04:16:22 pm »
Yep, that Pioneer PLX1000 looks like a hit.  No gimmicky LEDs, buttons or glitzy futuristic design:  http://pioneerdj.com/english/products/turntable/plx-1000.html
Raising the bar...
Atlanta Wedding DJs
Atlanta DJs / Wedding DJs / Prom DJs ...and more
Re: A good pro TT
Page created in 0.04 seconds with 23 queries.
