Pages: [1] 2 3 4   Go Down
Author Topic: Tannoy VQ series compression driver  (Read 13727 times)
Adrian Bamford
  • Is it that time already?
« on: February 18, 2014, 09:20:46 am »
Hi All,
Does anyone know what size compression driver is in the Tannoy VQ60, VQ100 and the down-fill boxes ? It's referred to in all the Tannoy specs simply as 'Dual Concentric Compression driver loaded into a single PSW Waveguide'; no size given.
I've recently visited a venue with several of these boxes flown, and the high-end is not great - like the PA had a blanket over it. I'm looking to find out why.
Regards,
Ade
Re: Tannoy VQ series compression driver
« Reply #1 on: February 18, 2014, 09:39:51 am »
Hi All,
Regards,
Ade
System tuning and voicing, perhaps.  There are lots of complicated bits between the microphone and loudspeaker.
Adrian Bamford
« Reply #2 on: February 18, 2014, 10:49:00 am »
Granted - but this is Just a Beta '58 into an AH iLive console input with flat everything, then into a Labgruppen C:28.4, and then into the VQ60. A professional sound system shouldn't, and usually doesn't, take any form of system tuning to make that sound at least passable.
« Reply #3 on: February 18, 2014, 11:09:05 am »
Have you taken your concerns to Tannoy?
Mike Pyle
  • Santa Rosa, CA
« Reply #4 on: February 18, 2014, 11:28:04 am »
The VQ60 and VQ100 are both spec'ed as "bi-amp or tri-amp" systems, so there must be an active crossover or processing in there somewhere. As to the driver sizes, here is a description from an A&E sheet on the web:
"The loudspeaker shall consist of a Dual Concentric™ Compression driver with a 3.5” Midrange voice coil and a 2” High Frequency voice coil, both mounted in a common subsystem with a common 2" exit. This Dual Concentric™ compression driver shall be coupled to a PSW™ (Point Source Waveguide) constant directivity horn operating over the frequency range of 450Hz to 23kHz. The low frequency section consists of two 12” (300mm) woofers, and shall be mounted in a semi-horn loaded enclosure to provide significant off axis attenuation below 450Hz."
  • Old enough to know better
  • Audio Plumber
« Reply #5 on: February 18, 2014, 11:57:21 am »
There seems to be a critical component missing from that signal chain, the crossover. The VQ-60 is bi amp or tri amp only, you must have an active crossover or DSP and 2 or 3 amp channels to power all of the drivers.
HERE is the spec sheet.
Jens Palm Bacher
    • Lydfabrikken
« Reply #6 on: February 18, 2014, 12:21:20 pm »
Hi All,
Regards,
Ade
BMS 4592
gordonmcgregor
« Reply #7 on: February 18, 2014, 02:00:23 pm »
As has been said there needs to be at least a bi-amp crossover and I would say that a lack of high end is not the usual complaint with these boxes so something isn't set or wired right, there should be enough  power in that amp to drive 2 cabs in bi amp mode at least. If it bothers you and you can get access to the amps etc have a look for whatever processor is there and check it's settings with the ones published on Tannoy's website. G
Adrian Bamford
« Reply #8 on: February 18, 2014, 02:17:38 pm »
Thanks all, It's not really my gig or anything; I was asked to take a listen because no-one could get any vocal level in a band situation. A complete lack of real high-end stick out like s sore thumb. I'll dig a little deeper and see what's going on. Ade
Art Welter
« Reply #9 on: February 18, 2014, 02:35:19 pm »
A complete lack of high end would indicate the HF portion of the coax is burnt out, leaving virtually no response (steep roll off) above around 6 kHz.
Beta 58 would sound like it has a pair of gym socks over it.
Pages: [1] 2 3 4   Go Up
Page created in 0.042 seconds with 23 queries.
