Author Topic: Image looks purple using VGA  (Read 2199 times)
Tamar Ghobria
« on: November 25, 2013, 06:45:28 am »
Just purchased the Roland V-40HD and seems to work great using HDMI inputs....The issue I am having is that when plugging in a VGA cable the image looks Purple...The source was a macbook pro....One suggestion was to turn overscan off on the laptop....Also to try different VGA Cables.
Ryan C. Davis
  • SL,UT
Re: Image looks purple using VGA
« Reply #1 on: November 25, 2013, 08:37:59 am »
Overscan won't do anything to help a purple picture. It's function only controls geometry.
Try a different cable and make sure that its firmly seated on both ends. Then also make sure both your source and display are set to rgb color space.
Ryan Davis
TonyWilliams
  • Nashville, TN
    • Blog
« Reply #2 on: November 25, 2013, 09:47:25 am »
Most likely it's the VGA cable. You're missing the green pair of pins somehow.
- Tony Williams
____________
Tony Williams
June Audio Video
Blog
George Smith
« Reply #3 on: November 25, 2013, 01:25:58 pm »
I agree.....Green is missing. You have changed the VGA cable, so one may assume that the connection to the projector or the laptop has an issue
Steve Ferreira
« Reply #4 on: December 27, 2013, 11:00:09 pm »
Check the color space on the switcher.
Page created in 0.041 seconds with 22 queries.
