Josh;
If your not running stereo you could go the dual PA route.
Use 1 amp channel to run the sp2's and the other amp channel to run the sp5s.
Pan the vocals to the amp channel running the sp5s (or sp2's , ) and have the other amp channel running the guitars,drums,keys, etc. to the other channel. I don't know if your a DJ then of course this won't work. I ran into a very Low Power gig this July 3rd. 1 - 15 amp - 120 volt power supply for the whole band as well as miss matched speakers. I used their QSC K12s for vocals and my old SP2x's on bridged cs800s amps with 4 powered subs for the whole show. I just limped by but the 2 different speakers not reproducing the same program material worked out very well. ( You can see in the picture the cord coming from the 2nd story window ) When I panned vocals to both speakers the sound fell apart and didn't work at all. But using one type speaker for vocals, the other for the rest of the band did work.
May get you by and in the end sound good doing so.
Douglas R. Allen
