Author Topic: Bose Room Match Speaker Systems??  (Read 16350 times)
Re: Bose Room Match Speaker Systems??
« Reply #10 on: May 28, 2013, 05:40:51 PM »
Because it has no handles and is painted white it must not be that good!
Well black boxes are louder ya know.
Brad Weber
  • Marietta, GA
« Reply #11 on: May 29, 2013, 07:24:02 AM »
Also, for a dual 10" the physical size of the thing is Huuuuge. The cabinet has a lot of (what seems like) wasted space in front of the drivers, but behind the grill. These things are literally the size of most dual 15 cabinets.
I think that may have something to do with being able to offer cabinets with 55, 70, 90 and 120 degree horizontal patterns as getting horizontal pattern control to a lower frequency as the RoomMatch boxes apparently do requires a physically large horn.
Being able to somewhat combine a vertical line array with elements also potentially having varying horizontal patterns is what makes a RoomMatch system different than either a typical line array or a traditional 'point source' box.  Whether you like the particualr products or not, the concept is interesting.
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
« Reply #12 on: May 29, 2013, 03:22:57 PM »
That's the only thing I could think of, but the couple of times I've seen the system I never saw any of the boxes that would "fill up" that space behind the grill. The rigs I saw had different modules, but I'm not sure what type boxes were being used. It may be that the narrowest horizontal module uses all that room....
Tom Hester
  • Orange County, CA
« Reply #13 on: May 30, 2013, 03:01:58 AM »
So are you saying that all "install" boxes sound the same?
How does the sound of an "install" box differ from "other boxes"?
Calm down over there. Install boxes meaning EAW MK, Yamaha Installation series etc.
There is a difference in sound quality between an MK box and d&b q7.. but there is also a huge price difference... The roommatch is in a weird spot being closer to the price of the high end system, but not having the sound quality in my opinion.
« Last Edit: May 30, 2013, 03:03:46 AM by Tom Hester »
Tom Hester
  • Orange County, CA
« Reply #14 on: May 30, 2013, 03:08:53 AM »
Perhaps it relates to Consultant projects, but I know the first part of that is not true as when I mentioned considering RoomMatch for a project Bose offered any assistance I wanted but also gave me a full copy of Modeler so I could look at it myself.  There was also nothing said about it being limited to only certain installers.  I did not end up using RoomMatch due to the output issues noted for what was a pretty large space but the variable pattern boxes, which is the real differentiator from most other products, can be advantageous in some applications, for example to create a more rectangular coverage from single center array.  The Renkus-Heinz Varia is a variation on the same concept.
Interesting, I sat through a demo with bose, That is where I was told that they do the design work, and are working with a network of installers... Maybe that rep was mis-informed.
« Reply #15 on: May 30, 2013, 05:09:53 AM »
I was just responding to the actual statement.  We have install boxes that sound exactly like the touring products-so not ALL install boxes sound the same.
So do all "install" front loaded boxes sound like all "line array" boxes?  I think not.
Now if  you are calling all "install" boxes-the cheap-bottom of the line" then say that-not "install" boxes.
BTW I would argue that installs done properly-sound wayyyy better than the typical tour boxes used in portable situation.
So maybe THAT is your point-not sure.
Brad Weber
  • Marietta, GA
« Reply #16 on: May 30, 2013, 08:53:06 AM »
Not necessarily, sometimes manufacturers approach projects that are designed and specified by independent consultants differently.  A manufacturer may have approaches for and/or relationships with dealers that make sense for design-build situations but may discourage consultants specifying their products and in those situations the manufacturer may try to find ways to be more 'consultant friendly' when a consultant is involved.  So what you were told may apply to design-build projects but not necessarily to those where what the manufacturer considers to be a qualified independent consultant is designing and specifying the system.
Tom Hester
  • Orange County, CA
« Reply #17 on: May 30, 2013, 11:07:24 AM »
I agree with you, a well done install can obviously sound better than a touring situation. I also never stated that "install" boxes sounded bad. I was stating for the price, they sounded no better to my ear than most manufactures install series boxes. I never brought up high end install boxes like Danley. Most manufactures take the handles off boxes and call them install boxes. im referring to contractor/install series with the same basic boxes with multiple horn patterns.I'll be more specific next time.
Tom Hester
  • Orange County, CA
« Reply #18 on: May 30, 2013, 11:08:45 AM »
Yes, this was meant for design/build.
