Author Topic: Pro Sub Suggestions  (Read 13561 times)
Art Welter
Re: Pro Sub Suggestions
« Reply #10 on: May 17, 2013, 01:27:47 pm »
This misses the point of this system, it is the same size or smaller than virtually all dual 18 inch subwoofers, offers lower distortion and less power compression AS COMPARED to dual driver systems.
Yes it is true when looked at as a quad driver system it would be 3 dB louder if it was not an isobaric design it would also have to be 3dB bigger.
And as for a horn loaded alternative it would have to be much larger to go anywhere near as low as a vented system, but you do get the efficiency.
Kenneth,
Since you don't post any frequency response curves, hard to compare sensitivity or efficiency of the AS-418 to anything else.
The  EAW SB-1000/1000Z/1000ZP have half space sensitivities from 99-102 with similar LF claims as the AS-418 in a slightly smaller cabinet, 15.64 cubic feet compared to the AS-418 at 16.54 cubic feet.
An SB-1000z was compared to the smaller Danley TH-118 tapped horn (14.41 cubic feet):
http://soundforums.net/varsity/6793-th118vssb1000z.html
The slightly smaller single driver tapped horn had slightly more upper output, the SB-1000 slightly more extended LF.
The B&C 18SW115-4 used in the DSL TH-118 has more Xmax than the drivers used in the AS-418 (look like a shorter winding version of the B&C18TBX100), my money would be on the TH-118 having higher ultimate output.
As far as the reduction of even order distortion (leaving the odd sounding odd order distortion) the push pull isobaric arrangement provides, that would be something to consider, though it seems few care about even order distortion, as it makes a sub "sound louder".
Art
Kyle_Keating
« Reply #11 on: June 03, 2013, 03:24:08 am »
This misses the point of this system, it is the same size or smaller than virtually all dual 18 inch subwoofers, offers lower distortion and less power compression AS COMPARED to dual driver systems. It is competitively prices to DUAL driver systems. It has the same efficiency as a dual driver system 2x the power handling and 1/2 the power compression for a given output as compared to DUAL driver systems.
One of our key design objectives is real output after power compression and in this the AS418 work, suggest you listen to it compared to similar sized dual driver system a we are confident you will be impressed.
Sorry if I am ranting but been traveling to long today!
I'll have to try and make a point to hear one of these subs one day. I honestly can't speak too much on this because I have never measured one or heard one.
Page created in 0.098 seconds with 22 queries.
