Author Topic: Rat Sound Tools  (Read 14922 times)
Craig Leerman
  • Global Moderator
  • Do Not Read This!
Rat Sound Tools
« on: January 07, 2013, 08:48:26 PM »
Cables present plenty of problems in audio systems, and it's something Dave Rat and the gang at Rat Sound have been addressing with a growing line of SoundTools products. I recently received several units to check out, including the XLR Sniffer/Sender, the NL-4 Sniffer/Sender, the 1/4" Sniffer/Sender, and the Mic Swapper.
The sniffer/senders are cable testers, but unlike many devices of their type, they can be used to check cables/snake channels when they're in place at a show or installed at a venue and the two ends are not near each other.
All have two components. The XLR Sniffer/Sender, for example, includes a small "sender" unit with an XLR female plug on one end and a recessed switch on the other. Unscrewing the switch end opens up the battery compartment, which houses a small A23 battery. The even smaller "sniffer" unit includes an XLR male plug and three recessed 2-color LED lights labeled a, b and c on the other.
The 1/4" Sniffer/Sender is very similar in size and function, and as the name states, both ends accommodate 1/4-inch tip-ring-sleeve (TRS) terminated cables, with the sniffer end including the same LED capacity as the XLR unit. The NL-4 Sniffer/Sender has 4-conductor Speakon jacks (both ends), with the sniffer end outfitted with four recessed 2-color LEDs that can indicate a wide range of problems.
Meanwhile, the Mic Swapper is a 2-input/2-output unit with swappable outputs. The business end is a cylinder made of metal with a rugged, metallic cap switch on the end. Four CBI brand 22 AWG microphone cables exit the rear of the housing from a beefy cable clamp. The cables are about 54 inches long and terminate into rugged Amphenol XLR ends.
Testing & Tracking
A pile of cables in my shop, just back from a gig, provided a great opportunity to check out these tools. First I tested a single XLR cable, and the sniffer showed three green lights meaning the cable was good.
What a good cable looks like:
Next up was a small stage snake, which is something a sender and sniffer style unit is really made for. The first channel of the snake was good, but the second channel of the snake showed only two green lights. Not even 10 minutes on the job, and the unit had found an incorrectly wired snake channel.
Two green lights on the XLR Sniffer/Sender means that pins 2 and 3 are swapped or shorted. Since I've been using that snake for more than 15 years with no problems, I guessed that they were swapped. A check with a meter verified that my hunch was correct.
It was at this point that I discovered my only (and albeit minor) dislike. There is no legend printed or engraved on the body of the sniffers that can tell you what the lights mean. However, a legend (on paper) is included with each unit, so I made a copy of the original and taped it around the body of the sniffer so I'd know what the light combinations meant.
When I mentioned this to the folks at Rat Sound, they noted that a legend used to be provided in sticker form so that it could be attached to the body. The great thing is that they're going to start providing the stickers again. Problem solved!
The next few hours were spent going over every one of my snakes, and after all channels received a clean bill of health, I moved on to using the other tools. The 1/4" and NL-4 Sniffer/Senders were just as easy to use, and I went through another pile of cables on the bench in no time. With the mixer set up, I also discovered that the XLR Sniffer/Sender can also be used to check for phantom power. This is really one handy tester!
NL-4 unit
Focus then turned to the Mic Swapper. I placed a small mixer on the bench and set up two microphones. By turning the switch, mic "a" went from channel 1 into channel 2 and mic "b" went from channel 2 into channel 1. This would be great for swapping out the lead vocalist mic to a spare during a show. The Mic Swapper also works well as a mic tester, allowing me to switch between a pair of mics to compare their sound.
Mic swapper:
Proving Their Worth
I took the units to a corporate event where I normally place two podium mics (one serves as the spare). Instead of using two separate channels, I ran both mics through the Mic Swapper and then to a single channel on the console. The switch was easy to use with one hand, and will even fit into a mic clip so it can be positioned at the ready.
The next gig was a larger corporate general session, but this time I was free-lancing as an audio stagehand for another company. While setting up the audio system, we realized that one of the feeds to video world was not working. I traced the problem to a suspect cable, and then pulled the compact XLR Sniffer/Sender out of my pocket and found that pin 2 on the cable was open.
Another guy on the crew saw the units and wanted to check them out, and by day's end, every stagehand had seen and played with the three sniffer/sender units. They all remarked that they wanted at least one, if not all three, for their own toolbox.
The final gig was a small corporate meeting, where this time I utilized the Swapper with a pair of wireless mics, making the second wireless a spare for the main presenter. Overall, the Rat SoundTools are winners, and I'm adding them to my kit. With a few of these and a handful of turnarounds and adapters, they facilitate remote (and very quick) testing of any cable encountered at a show.
Prices direct from www.soundtools.com include $45 for the XLR and 1/4" Sniffer/Senders and $99 for the NL-4 Sniffer/Sender and Mic Swapper.
TechWorksReno.com
Facebook.com/TechWorksReno
Pinterest.com/TechWorks0492
Greg_Cameron
    • Cameron Pro Audio
Re: Rat Sound Tools
« Reply #1 on: January 08, 2013, 02:18:04 PM »
One thing Dave Rat mentioned years ago about the Sender for the Sniffer/Sender pack is that in a pinch, it can be used as a phantom power supply with an XLR Y cable so long as the mic can run on 12v. I've done this on a couple of occasions. Pretty handy!
Cameron Pro Audio
brian maddox
  • HeyYahWon! ttsss! ttsss!
Re: Rat Sound Tools
« Reply #2 on: January 08, 2013, 08:32:46 PM »
yeah, this product is a very cleaned up version of the little phantom power testers i used to make up and use back in the day.  just a switchcraft male connector with the rubber strain relief removed.  i'd solder a red LED from pin 2 to 1 and a green LED from pin 3 to 1 and then fill the connector up with clear silicone.  then all you had to do was put phantom on a line and you had a quick single ended cable tester.  only green or only red meant dropped leg.  no light meant dropped pin 1.  great for troubleshooting signal problems through multiple subsnakes and multi pins.
anyway, i'm glad to see someone take the idea and make a credible product out of it.  just wish it had been me.  :)
brian maddox
bdmaudio@gmail.com
Ben Clark
Re: Rat Sound Tools
« Reply #3 on: July 30, 2013, 03:27:59 PM »
I purchased the XLR sniffer/sender and have to say it is a great tool for any professionals workbox; quick and easy to use and built to withstand the rigors of the road.  When I unpacked mine for the first time the sender part did not work so I dropped a line to the good folks at Rat Sound and within minutes I had a reply from Dave's assistant and before the week was out I had a replacement in my hand... that's the kind of people you want to do business with!  It's great for testing short cables, long cable runs and snakes (as long as they are not transformer isolated).
Doug Fowler
  • Saint Louis, MO USA
Re: Rat Sound Tools
« Reply #4 on: July 30, 2013, 03:30:31 PM »
Read the rules, fix your display name.
Thank you for your cooperation.
Ben Clark
Re: Rat Sound Tools
« Reply #5 on: July 30, 2013, 05:10:49 PM »
Done.  Sorry I missed that part when registering  :-[
Re: Rat Sound Tools
Page created in 0.068 seconds with 24 queries.
