Author Topic: speaker cable melted to the input jack  (Read 2716 times)
John Luty
« on: November 29, 2012, 03:59:26 pm »
actually the plastic nut on my Peavey pv118 melted to the cable .That input is shot but do you think the rest of the speaker is damaged? I didn't see any other thing wrong
Re: speaker cable melted to the input jack
« Reply #1 on: November 29, 2012, 06:31:23 pm »
The heat is caused by the resistance due to the poor connection of a 1/4" connector.  It is quite amazing how hot a 1/4" plug/jack can become.  That is why it is not used as a pro connection (and other reasons-damping factor-again due to high resistance of the connection and so forth).
There is no way to know about the speaker.  Of course it could have been a blown speaker that caused the excessive current.
The only way to tell is to take the speaker out and see.  Put a 9V battery across the loudspeaker terminals and see if it "pops".  If it does-then that is a good sign.
If not you need to dig a bit deeper.
John Luty
« Reply #2 on: November 29, 2012, 08:25:56 pm »
is a difficult to replace the melted jack with a speakon ?
« Reply #3 on: November 29, 2012, 08:37:12 pm »
Depending on the plate and room available.  You might just have to drill out a larger hole ( a step bit is good for this)
Page created in 0.065 seconds with 23 queries.
