Author Topic: distortion help  (Read 5141 times)
John Luty
Re: distortion help
« Reply #10 on: November 24, 2012, 06:42:42 am »
My board (Peavey PV 20 ) doesn't have a solo so no I didn't do that and yes I could hear some distortion in the headphones
g'bye, Dick Rees
  • Duluth
Re: distortion help
« Reply #11 on: November 24, 2012, 08:43:26 am »
So the distortion is likely happening within the board itself.  If it's functioning as it should and doesn't need any repairs, either the input gains are set too high and you're picking up distortion there (indicated by only specific sources distorting) or the summing amps which combine the individual channels are being overloaded.
How are you setting your input gains if you have no "solo" or "cue" button?  One likely scenario is that you're setting your channel input gains too hot.  With a bit of "creep" in the levels coming off the stage over the course of a few hours, this could put you over the top with your little Peavey desk.
Something is changing between the first and last sets.  You just have to figure out what.  Operating your inputs hot is likely to be the first place to look.
Again, how do you determine your channel input level settings?
Mark McFarlane
  • Middle East
    • Arkose Records
Re: distortion help
« Reply #12 on: November 24, 2012, 09:00:46 am »
John, your mixing console seems to have a fairly foolproof clip light on each channel, just above the faders.
Quote
Clip/Mute LED
This light normally indicates that the channel signal level is nearing the overload point, but it also lights when mute is engaged. The clip indicator circuit monitors the signal at many points in the channel to ensure that it catches all instances of clipping. It illuminates at +19 dBu and warns that the gain or EQ boost should be reduced. When it lights, roughly 3 dB of headroom remains.
If this light starts lighting red you are 'almost' at the point of distortion for that one channel.  Try to keep the lights out of the red by turning down the gain knob at the top of each channel strip (or turn down the EQ if you have a lot of EQ boost on a channel).  If you turn the gain all the way down and are still in the red, then there are a variety of different fixes depending on what the input is (a keyboard, a mic,...).
The Peavey manual gives instructions for how to optimally set the gain knob for each channel.  This is an important step, and it may need to be repeated during the night as the band gets louder. http://www.peavey.com/products/index.cfm/item/699/116338/PV%26nbsp%3B20%26nbsp%3BUSB
Quote
Gain
This control establishes the nominal operating level for the channel.
The input gain can be adjusted over a wide range to compensate for soft voices or very loud drums. To maximize the signal-to-noise ratio, the gain should be set to the proper level, with the channel Fader (12) set to 0. If the clip LED comes on and remains lit, try reducing the gain.
There are also clip lights on the effects unit and on the master fader.  In general, you want to avoid having any of these light up red during the show.  An occasional red blink isn't too bad...
FWIW, overdriving channels into distortion is the most common cause of distortion that I see, time and time again, when helping new people learn to mix, so I'd look here first.
« Last Edit: November 24, 2012, 09:04:34 am by Mark McFarlane »
Mark McFarlane
ARKOSERECORDS
Turn down what's too loud.
g'bye, Dick Rees
  • Duluth
Re: distortion help
« Reply #13 on: November 24, 2012, 10:23:38 am »
I tried the link and the PDF manual is tedious to say the least.  Here's what I imagine they might say:
1.  With signal present at the input, raise the gain (trim, pre-amp, whatever) until the clip light blinks red, then back off a bit.
OR
2.  Set the Master fader and the channel fader to "0", then raise the channel gain until the mains output LED's show a level of -3.  Be sure to return each channel fader to its lowest point after setting the gain this way.  You only want the meters to read the channel you're adjusting.
Option #2 lets you use metering for a more precise setting.
DR
David Parker
Re: distortion help
« Reply #14 on: November 24, 2012, 10:59:36 am »
Ok first set sounded great second set was good too but by the end of the third set vocals were getting distorted .Is it possible that the amps are getting hot? could it be that the speakers are getting weak? I didn't make any changes other than SLIGHT changes like turning up a solo then dropping it back down
one common mistake when learning to run a sound board is to gradually turn the channel faders up when something isn't loud enough. After a while the overall mix is too loud, so they turn down the master fader. After repeating this exercise many times, every channel fader is way up and the master fader is way down. There's an old saying that was spawned by this, never have a channel fader above the level of the master fader. This is not a hard set rule, but it's something to watch. You can overload the summing amps ahead of the master fader. In other words, no separate channel clipping, but the sum of them all clipping ahead of the master. Knowing what to turn down is just as important as knowing what to turn up.
John Luty
Re: distortion help
« Reply #15 on: November 24, 2012, 03:15:54 pm »
David I think you are on to something I did have a clip light on a vocal channel that would blink (maybe too much ) and I did ask my son if they were turning up their amps on stage ,which they were ,so the over all mix was screwed up .That's why I use this forum a TON OF GOOD PEOPLE THAT ARE WILLING TO HELP
g'bye, Dick Rees
  • Duluth
Re: distortion help
« Reply #16 on: November 24, 2012, 03:31:17 pm »
This is what happens when a vocalist "sandbags" the sound check.  Not matter what you say, most singers will not give you their performance level at sound check, so you have to hedge your bets and either set their input gain low to begin with or be prepared to lower it once the action starts.
The main problem here is that any change in input gain will affect both the mains and the monitor mix, so if and when you lower the channel input gain on the offender, you have to remember to then boost the monitor aux send for that channel to compensate.
Re: distortion help
Page created in 0.03 seconds with 23 queries.
