Pages: 1 2 [3] 4 5   Go Down
Author Topic: Danley SM80- first impressions  (Read 31378 times)
BryanRamsey
Re: Danley SM80- first impressions
« Reply #20 on: December 22, 2012, 10:15:47 pm »
What is the throw distance?  Any ideas what is reasonable to expect out of the box before fall off?
In the first room we did, we had to pull a lot of 300 Hz out of the room for some reason.  Other than that, it sounded very good with no processing outside except for the crossover HPF.
Jay Barracato
  • Solomons, MD
Re: Re: Danley SM80- first impressions
« Reply #21 on: December 22, 2012, 10:43:39 pm »
??? All boxes fall off at exactly the same rate. One of those pesky physics laws there is no way around.
Jay Barracato
g'bye, Dick Rees
  • Duluth
« Reply #22 on: December 22, 2012, 10:55:38 pm »
Drat!!!!  A good straight line like that and you beat me to it......
« Reply #23 on: December 23, 2012, 10:27:37 pm »
Along the lines of "how many people will that speaker cover"
In the case of the SM80-it will cover 1 person pretty well (if facing straight down).  2 people if they are close friends.
It is not the number of people-but rather the spacing of the people-AND how loud the program content is if the real question is "How many people could be in attendance and still hear good".
It is one thing to be doing jazz and another doing rock and roll.  And are the people seated at round tables or standing close together?
The same speaker will give VERY different results.
Hence the need to PROPERLY DEFINE the needs.  Loudness-distance-width etc. Distance and width are pretty easy-but getting a usable target SPL number is quite another.  Is that number continuous-peak-what weighting?  Is it realistic?  Are we allowing "extra headroom" for the loudspeaker so it doesn't blow up?
What about the "sound quality SPL"?  Just because a particular speaker can produce 130dB, does not mean that you can listen to-or would like the sound quality of it that loud.  It might be that 125dB (or less) may be as loud as you would want to run it.  So that number (that you won't find on any spec sheet) is the number for the calculation.  And different people have a different idea of what is "usable".
Of course that is NOT the answer people want to hear.  They typically want a simple-easy to understand WRONG answer.
Sorry-but that is just the way it is.
Caleb Dueck
« Reply #24 on: December 23, 2012, 11:22:56 pm »
Ivan's answer is too complex.
88.575'.
Keith Broughton
  • Toronto
« Reply #25 on: December 24, 2012, 08:02:10 am »
12" coax @ 80 deg. should work very well as a single monitor cab.
Anyone tried it yet?
John Fruits
« Reply #26 on: December 24, 2012, 05:39:45 pm »
In post #16 Ivan mentions a bit about the SM80M.
There is also a picture on page two of this thread found elsewhere.
http://soundforums.net/varsity/5689-danley-demo-11-13-atlanta.html
"The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs.  There's also a negative side."-Hunter S. Thompson
« Reply #27 on: December 26, 2012, 09:41:11 am »
88.575'.
OK now that we have a "simple answer" ;), exactly what does that measurement mean?  Is it taken from directly in front of the speaker?  Or at an angle to the center of the crowd?  Are you measuring from the front of the grill or from the acoustical origon?
These things are very important-because we need to squeeze the people into the coverage area.  I would hate for somebody to outside of the coverage distance.
Wink wink nod nod
Keith Broughton
  • Toronto
« Reply #28 on: December 26, 2012, 11:01:18 am »
So, has anyone tried it or the monitor version and how did it sound?
Rick Powell
« Reply #29 on: December 26, 2012, 05:12:20 pm »
My experiences with it (a REAL pair of SM80's) are documented toward the front of the thread.  It has performed excellently on the few occasions I have had it out so far, with great vocal intelligibility and relatively balanced pattern coverage.  I have not needed to crank it up to its limits yet, but all my apps have been indoors to 200 people or less.  If you have a specific question I will try to answer to the best of my knowledge.
Pages: 1 2 [3] 4 5   Go Up
Page created in 0.046 seconds with 22 queries.
