Author Topic: Ls9 and stagemix problem  (Read 8845 times)
Dan Richardson
  • southern Vermont
    • NotTooLoud
Re: Ls9 and stagemix problem
« Reply #10 on: July 02, 2012, 10:07:51 pm »
Problem not solved, but I could identify the cause.
When I use the LS9 with the Stagemix is fine. When I connect an iMac to record it's all fine. The problem is when I connect AC-7 Core Mini on the iPhone to control Pro Tools, that's when things go wrong. I don't know why, but I changed cables, IP adress, router... but I could not find a solution.
So, I think I will get a Presonus Faderport and a long USB cable to control Pro Tools, what do you think?
Run them on separate routers?
The best sound system is no sound system. Everything else is compromise.
Scott Wagner
  • Richmond, VA
« Reply #11 on: July 02, 2012, 10:10:05 pm »
+1.  I'll add to make sure each router is on a separate network.  Research IP Addressing and Subnet Masking.
Scott Wagner
Big Nickel Audio
Airton Pereira
    • The Knutz
« Reply #12 on: July 03, 2012, 11:09:11 am »
I tried something like this, but instead of using two routers I created a network in my iMac and connected just the iphone to it, but no success.
Drummer and Sound Engineer for The Knutz.
Page created in 0.026 seconds with 23 queries.
