Author Topic: Ls9 and stagemix problem  (Read 8897 times)
Airton Pereira
    • The Knutz
« on: June 14, 2012, 11:44:05 am »
Hi,
Does anyone have a solution for this problem yet? I cannot connect my ipad to the ls9 anymore! I recorded a video:
http://www.youtube.com/watch?gl=BR&hl=pt&client=mv-google&v=1KmBNw3ji0c&nomobile=1
« Last Edit: June 14, 2012, 07:09:50 pm by Airton Pereira Silva »
Drummer and Sound Engineer for The Knutz.
Denny Conn
    • Hult Center for the Performing Arts
Re: Ls9 and stagemix problem
« Reply #1 on: June 14, 2012, 11:57:04 am »
Hi,
Does anyone have a solution for this problem yet? I cannot connect my ipad to the ls9 anymore! I recorded a video: http://m.youtube.com/watch?v=1KmBNw3ji0c
I wish I had an answer, but all I can say is join the club.  Mine worked great for a couple weeks.  Now I can't connect.
Riley Casey
« Reply #2 on: June 14, 2012, 12:00:27 pm »
This is after you tried religiously and in excruciating detail all the suggestions at the bottom of this page?
http://www.yamahaproaudio.com/global/en/products/peripherals/applications/m7clstagemix/index.jsp
Hi,
« Last Edit: June 14, 2012, 12:06:06 pm by Riley Casey »
Airton Pereira
    • The Knutz
« Reply #3 on: June 14, 2012, 12:06:34 pm »
Riley, once the console gets slow, I cannot reconnect at all until I turn it off and on again.
Riley Casey
« Reply #4 on: June 14, 2012, 01:27:50 pm »
If the console hardware is being affected by its link to the ipad that sounds like a failure of the hardware or a bug in the consoles own OS.  Time to escalate this beyond asking around on the net to a Yamaha service call.  Probably with some metrics in hand like a video of the console screen exhibiting it's slow behavior.
Airton Pereira
    • The Knutz
« Reply #5 on: June 14, 2012, 07:07:57 pm »
Really? This sucks, I will call for Yamaha service. Thanks.
Stephen Gordon Askins
« Reply #6 on: June 14, 2012, 10:07:32 pm »
Hi,
Hi, I had a similar problem a few weeks ago.  Fortunately I was able to remember what I had changed when I last used that console the week before.  During set up I noticed the clock was an hour out so I changed it to the the correct time.  The next time i used the console I couldnt get the Ipad to see the console. Eventually I remembered the clock issue; reset the the clock to an hour in advance and immediate success !!  Was very weird.
Airton Pereira
    • The Knutz
« Reply #7 on: June 15, 2012, 09:28:56 am »
You mean before connect the iPad to the console or when the connection is lost? This just solved the problem, just adavance time? That┤s really weird but I will sure try it later! Thanks.
Airton Pereira
    • The Knutz
« Reply #8 on: June 15, 2012, 06:47:16 pm »
Problem not solved, but I could identify the cause.
When I use the LS9 with the Stagemix is fine. When I connect an iMac to record it's all fine. The problem is when I connect AC-7 Core Mini on the iPhone to control Pro Tools, that's when things go wrong. I don't know why, but I changed cables, IP adress, router... but I could not find a solution.
So, I think I will get a Presonus Faderport and a long USB cable to control Pro Tools, what do you think?
« Last Edit: July 01, 2012, 08:58:53 pm by Airton Pereira Silva »
Airton Pereira
    • The Knutz
« Reply #9 on: July 01, 2012, 08:59:25 pm »
┬ź Reply #9 on: July 01, 2012, 08:59:25 pm ┬╗
Page created in 0.026 seconds with 22 queries.
