Author Topic: 70v speaker placement at driving range  (Read 8886 times)
Steve Toulch
« on: May 29, 2012, 12:15:38 pm »
Were looking at installing a 70v distributed system at our driving range.
Wed like something for background music not so loud as to irritate the guests teeing off, no booming bass, mainly rock / pop tunes.
I'm looking at the entry level Yorkville C110 Coliseum Mini speakers because they have taps for 10, 20, 30 watts. Was also looking at the JBL entry level control speakers but they only have a 5w 70v option and they're twice the price.
Ive attached a drawing of our facility with measurements. Im trying to determine how many speakers we will need for good coverage (my preference is to have more speakers at lower volume so there are no hot spots). I was thinking of using 14-16 speakers place approx 16' apart and attached to the top of our 4' fence.
We plan on using a Yamaha mx6150 amp capable of 70v 240watts bridged and running 14/2 speaker cable through conduit.
How many speakers would you recommend?
Would we be better off running them on 2 channels or bridging the channels?
thanks for your help!
Re: 70v speaker placement at driving range
« Reply #1 on: May 29, 2012, 05:43:20 pm »
First and foremost-the speaker choosen MUST be weather proof.  As they will be exposed completely to the elements.
Since you are not looking for high levels-and the speakers are pretty close to the people-you won't need a lot of level.
I would run a single 70V line and be done with it.
How many-that would depend on the budget-but since people are not there to listen to the music-the coverage does not need to be as even as you would normally do.  However you don't want huge gaps-because some tees would be loud and others quiet.
Of course this might be a good thing-and people could choose how loud they want the music?
g'bye, Dick Rees
  • Duluth
« Reply #2 on: May 29, 2012, 05:56:45 pm »
Steve....
I'd think that getting them up higher than the fence would be to everyones advantage.  Fewer "hot" spots and a more even and benign coverage.  Halve the mounting points, double up on the speakers at those points and splay them outward to even the coverage.
I'm just thinking that with them at only fence height you'll run into some problems with the "perceived" loudness and presence.
Ryan C. Davis
  • SL,UT
« Reply #3 on: May 29, 2012, 06:32:05 pm »
what about landscape speakers? It looks like a nice facility and I would think speakers on the posts or higher will be less desired aesthetically. With a similar arrangement of Landscape speakers you could accomplish the same end goal. It may not sound as good but as mentioned, the patrons aren't there to listen to music. The other pro is that the landscape speakers are meant to be directly exposed to the elements. There are actually some landscape speakers we've used that sound dang good. Of course, they come with a price tag.
Ryan Davis
  • Old enough to know better
  • Audio Plumber
« Reply #4 on: May 29, 2012, 06:53:01 pm »
The added advantage of landscape speakers is you may be able to get them closer to the tees so they can be run at lower levels so they don't bother the people in the rooms across the street.
« Reply #5 on: May 29, 2012, 07:46:55 pm »
And they would be on a lower tap-so less power required.
I would agree with the landscape idea.
I have only done one install with landscape speakers (we used a sub also (big rock) and it worked fine for the intended usage-and looked better than "normal" speakers.  So my mind went blank about that idea.  Glad it was brought up.
Steve Toulch
« Reply #6 on: May 29, 2012, 08:48:32 pm »
Thanks For all the resonses guys,
I'll reply to all the posts below:
weather resistant. The speakers I'm looking at are weather resistant. We're also worried about theft, so the speakers will be brought in each night (they're pretty small and easy to move) or we will build some boxes to house them. I'd stick a 1/4" connector on each speaker line, this would make it easy for staff to remove them and set them up.
I've looked at garden speakers, the problem is they are 3 to 4 times the cost per speaker. (including transformers between $150 - $200+ each). Also, there isn't much space between the tee boxes and I don't want speakers in front of the tee boxes where they can be hit with balls.
Mounting speakers higher up - this would be ideal, however it would change the sightlines along the fence not sure if our town will go for that, I guess I could also angle the speakers upward as well.
Mounting speakers together and "spraying" - I like this idea how would the coverage be compared with pointing the speakers straight and having them evenly spaced?
Rooms accross the street - haven't really put much thought into that, I figure the rooms are far enough away and the music would be at a low level. We also operate only during daylight hours, plus there is a semi busy street between the range and the hotels.
I've also attached a picture of the speakers along with specs.
Hal Bissinger/COMSYSTEC
    • COMSYSTEC
« Reply #7 on: May 29, 2012, 08:52:26 pm »
That was my first thought also. I've used these http://www.atlassound.com/Product.aspx?id=1334&pI=1330 several times and they are virtually indistructable and sound probably better than those "entry level" (what is that?) speakers that you have been looking at.
I would have concerns with them mounted at 4 feet on those fence posts with vandalism.
Edit:
Quote
... so the speakers will be brought in each night... I'd stick a 1/4" connector on each speaker line, this would make it easy for staff to remove them and set them up.
That's insane and the connector is far from weatherproof.
-Hal
Steve Toulch
« Reply #8 on: May 29, 2012, 09:12:05 pm »
Hi Hal,
the ATS183GS looks great, only issue is they are $300 each. How many do you think I'd need based on the measurements in my drawing? I guess they're also pretty low profile so they could be left outside for the entire season without getting ripped off?
My budget for the whole project (besides the amp which we already have) is 3k. That includes speakers, wire, conduit, connectors and a zone mixer (probably go with a samson or behringer model). So I'm thinking 2k-$2300 for speakers. I'm not opposed to spending more per speaker, it all depends on how many we will need in total.
I don't need the speakers to be fully "weather proof" if It's pouring rain, the range will be closed anyway and they would be brought in. Or I can spend a little more and get some that are weatherproof.
http://www.bhphotovideo.com/c/product/500854-REG/Atlas_Sound_SM42T_B_SM42T_B_Two_Way_Weather_Resistant.html
as far as vandalism goes, I'm not worried about it during daylight hours, after hours the speakers would be removed. Although this would be a pain in the ass everyday for staff.
Edit:
-Hal
« Last Edit: May 29, 2012, 09:40:25 pm by Steve Toulch »
    • COMSYSTEC
« Reply #9 on: May 29, 2012, 10:28:44 pm »
Quote
I don't ever remember paying $300 for them but it has been a few years. They absolutely get left outside- year round and they are not easy to remove from their buried base. I first saw them used in an amusement park that is on the Long Island Sound. Not only were they use throughout the park where they are subject to kids standing on them, they were also installed along the water side of the boardwalk and out on the pier where they are exposed to salt water. That was probably six years ago and they are still working fine.
I would space them about every 30 feet along the fence line.
-Hal
Page created in 0.034 seconds with 22 queries.
