Author Topic: New Outdoor DJ Sound System Reccomendations  (Read 8587 times)
James Kessell
    • Ultra Evolution
« on: March 16, 2011, 05:11:49 PM »
Hi, I am looking for someone that knows more about active system then myself or if I should stick with the standard amp rack and stack of speakers (expand current system). I was looking at the QSC HPR powered system and the JBL PRX series.
To give you a idea of what we do, I operate a new company that hosts car events mostly outdoors with 200-400 cars and 500-1k people. We would be using the system on a out door stage for a DJ and PA. I currently have the below system but am thinking about selling it for powered boxes. Let me know your thoughts! I am also open to other lines.
My current old system=
2 Peavey 3g's ( damaged drivers need to be replaced, is it worth it ?)
2 Yamaha S115V
2 Peavey 118 subs converted with 18 inch Eminance Kilomax Subs
Crown Ultratech 1010 and 2020 (1010 needs repairs)
Dave Scarlett
Re: New Outdoor DJ Sound System Reccomendations
« Reply #1 on: March 16, 2011, 07:18:35 PM »
I have a 153/118 setup and really like it, heavier than the K series of course. If you have cars spread out over a huge parking lot it will probably get sound out there to the last guys in the back. If it's 50/60's music up close to a stage it will do the job as well. For newer bass heavy DJ music you'll come up shy.
Kevin "DJ Wave" Boreing
« Reply #2 on: March 17, 2011, 06:56:23 AM »
I think you'd do well to pick up a PRX 625M system (2) with a pair of prx618s-xlf subs. The only thing you'll need to be warry of is having an extra fan or two in case you get one of those hot summer days and need to put a fan facing the sub amps on the back of the box.
This is a very strong system, and you could also most likely get away with the 615m over the 625, but I'd be wanting to have that 3 way system in an outdoor setting like that. Usually those kind of gigs don't need full coverage all over, just solid coverage around the stage area and main announcement spot.
James Kessell
    • Ultra Evolution
« Reply #3 on: March 17, 2011, 10:27:55 PM »
Yeah I will have to worry about heat due to being in florida. How have those systems held up to the road. I was also considering a set of EAW powered KF400a's for tops and some double 18's for the ground. I am just worried about those single cabs not getting out enough bass due to the nature of new music.
James Kessell
    • Ultra Evolution
« Reply #4 on: March 22, 2011, 12:15:33 AM »
Anyone else ?
Fernando Lopez
« Reply #5 on: April 07, 2011, 03:06:06 PM »
Anyone else ?
Get 4 ZXA5-60 and 4 ls801pb
Since those tops have 60 degree horizontal dispersion you can place 2 per side and with the 2 inch high the music will project longer. Those subs speak by themselves, they are really loud
Vince Gibbs
  • The only thing constant in life is change.
    • Pure Sound Entertainment LLC
« Reply #6 on: April 22, 2011, 06:03:07 AM »
Anyone else ?
I use 1-2 Yorkville Elite LS800P subs for events like this.  These things kill!!!  If you need a loud powered sub that makes the earth move, you owe it to yourself to hear these.
Mere words can not describe.
Vince Gibbs
www.puresoundent.com
Brad Weber
  • Marietta, GA
« Reply #7 on: April 22, 2011, 08:06:08 AM »
Can you explain how "with the 2 inch high the music will project longer"?
Fernando Lopez
« Reply #8 on: April 22, 2011, 08:16:38 AM »
Poorly Written
The EV ZXA5 has a 2 inch voice coil, 1 inch exit horn
It should cover the needs of the op
Stephen Snipes
« Reply #9 on: June 01, 2011, 12:17:25 PM »
personally not a fan of the prx series but then again that is partly because I have the vrx918sp.  I would go with the 4 zxa5 60 degree though of course.  I have the 90 degree version because 75% of my events I only need 2 tops.  With the QSC I would go with 4 K or KW 12" tops and 4 - 6 vrx918sp subs.  I like the yorks but to a certain extent
Page created in 0.02 seconds with 23 queries.
