Author Topic: Replacement Drivers t36  (Read 12760 times)
Nate Armstrong
« on: May 14, 2012, 12:48:01 PM »
I friend just purchased a used small pa system for small events
DBX drive rack pa
1 crown ce1000a
1 crown ce4000
2 Cerwin Vega v-152 tops
2 Cerwin Vega T36-750  ( 8 ohm )
he was told that one of the sub drivers had just been re coned. When we went to purchase the system one of the subs did not work.  The system was still purchased at a discount.  we are uncertain if the damaged sub is the newly re conned woofer,  or more likely the original sub is the one that is now damaged
after inspection of the sub enclosure the wiring was connected correctly , after testing the ohm load it has a .1 reading ( toast )
we have toyed with the idea of only replacing the damaged sub and seeing how the new sub works with the oem sub that still works properly.   I know its not a great idea mixing subs, but if we could find a driver that is very similar, would it be doable  temporarily, until we recoupe some of the money to purchase a 2nd driver.
Can someone recommend some good choices to replace the blown cerwin vega sub woofer ?  -thanks
Re: Replacement Drivers t36
« Reply #1 on: May 14, 2012, 05:44:31 PM »
I would look closer again at ALL the wiring in the cabinet.
It is VERY rare (but I have seen it a couple of times) that a "blown" driver has a .1ohm reading.  Most of the time it reads an open (wires acted as fuses- to protect the amp).
It is possible that you have a short somewhere inside the wiring of the cabinet-causing the very low reading.
Nate Armstrong
« Reply #2 on: May 14, 2012, 08:56:47 PM »
I attached the speaker directly to one side of the amp. Zero output.
« Reply #3 on: May 15, 2012, 07:26:41 AM »
And that is what I would expect with a .1 ohm resistance.
You FIRST need to find out what is causing that short.
Disconnect the loudspeaker DRIVER (I'm not talking about the cabinet terminals) and measure the terminals of the driver itself-without any wires hooked to them.
THEN you go from there to find the problem.
Nate Armstrong
« Reply #4 on: May 15, 2012, 09:24:22 AM »
the speakers and amp are 2 hours from me.   The reading was taken directly from the raw speaker and not the cabinet.  I feel it has been determined the speaker no longer functions. I am now looking for a replacement
« Reply #5 on: May 15, 2012, 05:49:55 PM »
Did you happen to look at the leadin wires (from the terminals to the cone) to see if they were touching?  I've seen that a couple of times.
I would suggest the best thing to do is the simply get the driver reconed.  That would be your cheapest way out-and would get the cabinet back to original functioning condition.
Are there drivers that would perform bettern in those cabinets?  Maybe.  But you may gain something in one area-and lose something in another.
The one thing you DON'T want to do with a horn cabinet-is to simply replace the driver with one that you "think" is better.  Often the result is worse sound-but people "think" it is better-because they did it themselves-so it HAS to be better-NOT.
Chris Carpenter
  • Baton Rouge
« Reply #6 on: June 01, 2012, 10:30:19 AM »
Absolutely what Ivan said; don't just drop a random driver in a cabinet, especially a horn, especially just one of a pair.
Getting it re-coned is probably your best option. These guys have a pretty impressive resume of re-coned Cerwin drivers: http://www.speakerrepair.com
If you have to replace, the proper driver is the FH18A (http://www.cimplesolutions.com/other/CV_International_Pro_Audio_Parts_List_2007.pdf). Perhaps see if Cerwin Vega can sell you a replacement (I've never owned any of their gear, so I cant vouch for their service).
Nate Armstrong
« Reply #7 on: June 01, 2012, 04:16:11 PM »
Thanks for all the help. ill let you know how it turns out
Chris Gruber
« Reply #8 on: June 04, 2012, 03:29:04 AM »
Actually the proper driver for the T36 is the L1815. Recone kits can be had here http://reconekits.com/cerwinvega1815-8.aspx and are available in 4 ohm and 8 ohm versions. These kits are decent, I used them in some T36s I used to have and they never let me down.
Chris Carpenter
  • Baton Rouge
« Reply #9 on: June 04, 2012, 07:56:28 AM »
L1815 is the original woofer, FH18A is the replacement.
Page created in 0.018 seconds with 24 queries.
