Author Topic: DMX Splitter  (Read 5258 times)
John Livings
  • Los Angeles, California
DMX Splitter
« on: March 19, 2012, 12:02:30 am »
Any suggestions on a DMX Splitter?
Things to look out for?
I looked at this;
http://www.enttec.com/index.php?main_menu=Products&pn=70572&show=description
Regards,  John
Nate Armstrong
Re: DMX Splitter
« Reply #1 on: March 19, 2012, 09:13:11 am »
http://www.chauvetlighting.com/data-stream-4.html    I just got it, so I have only used it 4 times. works great.  If you had 5 pin to 3 pin I think you could have a total of 8 splits.  I have only used 4 3pin splits.  you can also link units together
TJ (Tom) Cornish
  • St. Paul, MN
Re: DMX Splitter
« Reply #2 on: March 19, 2012, 09:25:03 am »
I have the Chauvet, too.  So far it's been fine - no frills, but functional.  There's an internal power supply, so no wall wart needed.  My only small complaints are that the case is a little thin, there's no removable IEC cord, and the data LEDs are a little bright.  None of these are dealbreakers, and the box is cheap, so those things are easily overlooked.
As far as I know, only each output block is actually isolated - not each jack, so if you use both the 3-pin and the 5-pin in the same section, they're not really isolated from each other - just a wiring convenience to choose either pin configuration for that leg.
Scott Hofmann
Re: DMX Splitter
« Reply #3 on: March 19, 2012, 09:52:30 am »
I looked at this;
Nothing but good things to say about the Elation Branch4. Have had several in operation for a few years and only one capacitor in one split has gone bad, and easily repaired.
Regards,  John
Scott Hofmann
duane massey
Re: DMX Splitter
« Reply #4 on: March 19, 2012, 09:57:38 am »
TJ, any of the units that offer 3/5 pin outputs are paired the same way. The Elation unit is similar in that regard.
If you're looking for cheap, there's this one:
http://www.usledsupply.com/shop/dmx-splitter-1-8.html
Haven't tried one yet, but I might pick one up just to play with at this price.
Duane Massey
Houston, Texas
TJ (Tom) Cornish
  • St. Paul, MN
Re: DMX Splitter
« Reply #5 on: March 19, 2012, 11:11:36 am »
Yes - exactly.
James Feenstra
Re: DMX Splitter
« Reply #6 on: March 19, 2012, 02:42:27 pm »
the 3 and 5 pin outputs on these units are paralleled, so you only get 4 discrete outputs, not 8
plugging into both outputs has the same effect as looping through another fixture in your chain
Elevation Audiovisual
www.elevationav.com
Taking your events to the next level
John Livings
Re: DMX Splitter
« Reply #7 on: March 20, 2012, 02:51:06 am »
Thanks for all the suggestions.
Thanks Duane,
Was not looking for "Cheap" however for the price ($52.00) I ordered one. (1X8) (12 V Power Supply not included).
I was also considering one of the Elation splitters (1X4), If the "U.S. Led" unit does not work out I will order one of the Elation units.
Regards,  John
« Last Edit: March 20, 2012, 03:03:06 am by John Livings »
Nate Armstrong
Re: DMX Splitter
« Reply #8 on: March 20, 2012, 12:20:34 pm »
Thanks Duane,
Regards,  John
Please follow up later down the road and let us know how it works out.. at that price, I may pick one up as well .
Re: DMX Splitter
Page created in 0.084 seconds with 24 queries.
