Author Topic: Any products out there comparable to Mpro418SP ??  (Read 3799 times)
Micky Basiliere
« on: January 31, 2012, 12:50:04 PM »
Does anyone here know of a single 18" powered sub w/ a filtered Speakon out like the JBL Mpro 418SP duel channel amp/sub that will power the mid/high cab aswell?? seems like all powered subs out there only power "themselves" not any satellite cabs... is the Mpro one of a kind??
Samuel Rees
  • Washington, D.C.
« Reply #1 on: January 31, 2012, 01:23:02 PM »
Curiously, why are you looking for a cab like this? If you are going to replace your rig a powered sub an top would do about the same it seems...
« Last Edit: January 31, 2012, 02:50:56 PM by Samuel Rees »
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
Re: Any products out there comparable to Mpro418SP ??
« Reply #2 on: January 31, 2012, 02:33:38 PM »
The Electrovoice SB2A does the same trick, but is not in the same class performance-wise. It may work depending on what you want to do though.
Chris Chambers
  • Melbourne, Australia
    • MAD Productions
« Reply #3 on: February 01, 2012, 04:40:21 AM »
I know Quest - a small to medium size audio company in Australia aimed at nightclub installs - makes a system with a 15" subwoofer with inbuilt auxiliary amp rated at 2x 300w@4ohm or 200w@8ohm as well as the inbuilt 600w amp for the sub...
Never used it so I can't say what is sounds like..
http://www.drumpower.com.au/Quest-QM1000A-Active-600W-Sub-W-2x-QM108-8-200W-Satellite-speakers-Pair.html
mark lonow
« Reply #4 on: February 01, 2012, 05:18:49 AM »
RCF makes a duel 15" like u describe:
http://www.rcf.it/products/pro-speaker-systems/4pro-series/4pro-7001a-ba
http://www.rcf.it/en_US/products/pro-speaker-systems/4pro-series/4pro-7001a-mh
David Morison
  • Aberdeen, Scotland
« Reply #5 on: February 01, 2012, 07:57:04 AM »
Some of the HK audio suff does this, and if I'm not much mistaken some Ffohn brand systems as well. Probably both more common in Europe though.
cliff truesdell
« Reply #6 on: February 01, 2012, 12:37:25 PM »
I believe the D'lite system from Dynacord will power several tops and passive subs. its about the same size as the 418.
Tim Weaver
« Reply #7 on: February 01, 2012, 01:45:06 PM »
http://www.dynacord.com/en/products/7/1/1/7_powersub315.html
4 amp channels lets you hang up to 4 tops and 2 additional subs on this one cabinet. It has a selectable crossover.
Seems to be aimed at the DJ market, but it's a fairly cool product. As with all other Dynacord products, we have no freaking idea how it sounds, or how much it costs....
Page created in 0.035 seconds with 24 queries.
