Author Topic: Video Humbucker  (Read 5632 times)
Kellen Tyburski
    • Kellen Tyburski | Audio Engineering
Video Humbucker
« on: January 06, 2012, 11:39:57 am »
Hey all...
Couple questions about video Humbuckers... from what I know, these are typically (always?) a transformer @ a 1:1 ratio...
What is it about the 1:1 winding ratio that actually eliminates the hum?
I have had a scenario or two where we have had noticeable video hum in our ballroom, when using lighting on dimmers in conjunction with audio and video. If the problem occurs, where is the best place to "insert" the humbucker? (between output of switcher & projector, between video component & switcher, etc)
In addition, anyone know of a good place where i can read more about the definition of ground loops, how to avoid/eliminate them. This is one of my 2012 resolutions - instead of "wingin' it" I need get comfortable with this concept.
Thanks!
attached is the one i have been using... we own 2 of the same
« Last Edit: January 06, 2012, 01:11:59 pm by Kellen Tyburski »
KT
David Buckley
Re: Video Humbucker
« Reply #1 on: January 08, 2012, 05:48:40 am »
Nothing, the winding ratio does nothing to eliminate the hum.  Having 1:1 just means you get the same out as you put in.  What eliminates the hum is (a) the presence of the transformer, and (b) there is no connection between the ground of the input and the ground of the output.
In video, you get a ground loop when there is a current flowing through the screen of the coax.  This is caused by different parts of the video system being plugged into outlets that have different earth potentials.  The coax outer is commoned to electrical ground.
First thing to do is to have a single common earth point for all the equipment, so the eaiest way to do that is to have everything running off a single outlet from the wall, and have a single distribution board (of whatever needed size) afterthat.
I have had a scenario or two where we have had noticeable video hum in our ballroom, If the problem occurs, where is the best place to "insert" the humbucker? (between output of switcher & projector, between video component & switcher, etc)
Now you;ve seen why hum loops happen, its usually fairly easy to spot whre to put the humbucker.  Often projectors are run from different power sources from the switchers and stuff, so betwixt switcher and projector is often the place a 'bucker i needed.
Kellen Tyburski
Re: Video Humbucker
« Reply #2 on: January 08, 2012, 11:52:30 pm »
Thanks for the help....helps a lot..  When you say the "screen of the coax"... what are you refering to, I have never heard this term..
KT
TonyWilliams
  • Nashville, TN
    • Blog
Video Humbucker
« Reply #3 on: January 09, 2012, 01:15:19 am »
I believe the shield of the coax is what he is referring to.
- Tony Williams
____________
Tony Williams
June Audio Video
Blog
Geoff Doane
  • Halifax, NS
Re: Video Humbucker
« Reply #4 on: January 11, 2012, 01:42:57 pm »
Without checking, I would have guessed that David was in the UK by his terminology.  It turns out he's in New Zealand, which from my North American perspective, is almost the same thing  :).
It also seems like the perfect time to relate this anecdote, which was told to me by a now retired colleague in the television business.
Many years ago, Ampex and Philips had some sort of joint venture going, probably a Philips switcher and Ampex VTRs.  They were putting together a booth at the NAB in Las Vegas, and were having all sorts of problems with hum in the video when the two systems were interconnected.  The Philips engineers were all running around muttering about "earth", and the Ampex guys were talking about "ground", and the frustration level was high.
Finally one of the Philips guys asks, "What is the difference between earth and ground, anyway?"
"About 10 f*cking volts!", was the answer.
GTD
David Buckley
Re: Video Humbucker
« Reply #5 on: January 11, 2012, 08:52:20 pm »
Yeah, I've heard that anecdote before.
"Screen" and "Shield" I guess depends on whether the cable manufacturer sells you "screened" cable or "shielded" cable.
This youtube video explains it far better than I could :)
Keith Broughton
  • Toronto
Re: Video Humbucker
« Reply #6 on: January 15, 2012, 08:07:10 am »
Quote
Also, watch when you connect a projector to a lighting truss that the C clamp is isolated from the metal of the truss.
This can cause the same "ground loop" problems as having different outlets.
Re: Video Humbucker
Page created in 0.117 seconds with 25 queries.
