Author Topic: VGA vs. RGBHV runs  (Read 13690 times)
Kellen Tyburski
    • Kellen Tyburski | Audio Engineering
VGA vs. RGBHV runs
« on: November 22, 2011, 04:54:25 pm »
Hey all.. Hoping you could shine some light on this for me... I've working quite a bit around NYC (a lot of hotel AV) and I notice certain crews stick to VGA, and others are loyal to RGBHV cables. Neither really seems to know exactly why. Sometimes there doesn't seem to be much of a reason, (ex: vga output on switcher --> RGBHV breakout --> RGBHV cable -- back to vga input)
 From the research I have done, RGB analog signal requires sync, and in a VGA cable H and V sync are carried on PIN's 13 and 14, and with rgb-hv cable the H and V sync are carried on separate cables, So I don't see much of a difference in terms of Sync.
Generally speaking, which cable is best to use, and why? Does VGA suffer from "multiplexing" just as composite/s-video cables do?
Thanks for any advice or resources you might be able to point me to!
-Kellen
« Last Edit: November 22, 2011, 04:58:49 pm by Kellen Tyburski »
KT
Gianfranco Favero
Re: VGA vs. RGBHV runs
« Reply #1 on: November 22, 2011, 05:36:49 pm »
-Kellen
Not sure why but with rgbhv you can do longer runs. with vga over 20m you start to get bad ghosting and stuff. The cables are more sturdy and the bnc connector is better than the vga.
Kellen Tyburski
« Reply #2 on: November 22, 2011, 06:20:45 pm »
I'm assuming (would love if someone could clarify) that is because Red/Blue/Luma are house separately from each other, as opposed to VGA?
KT
John Livings
  • Los Angeles, California
« Reply #3 on: November 22, 2011, 06:48:16 pm »
Rob Sayer has a website that might be helpful. (On Stage Lighting)
http://www.onstagelighting.co.uk/media-video/video-signals-idiots-guide-dummies/
Regards,  John
Collin Donohue
« Reply #4 on: November 22, 2011, 06:58:53 pm »
From the rentals perspective, the cables WILL gr damaged at some point. For us, we use RGBHV cables and use 6" adaptors when VGA is needed because its easier to repair a bad BNC connector than a VGA connector.
We still have VGA in our inventory, but only 50' and under for direct computer to projector connections.
Glenn James
  • Darwin, Australia
« Reply #5 on: November 22, 2011, 09:36:11 pm »
VGA is just a type of connector fitted to the RGBHV cable. The standard is the same.
You can often go further using RGBHV cabling though as VGA cables generally use thin cables with less adequate shielding to fit within the small cable jacket.
Brian Tennyson
« Reply #6 on: November 23, 2011, 05:09:08 pm »
Absolutely right, Glenn. A VGA cable might have other pins active, like monitor ID pins for communication between a display and a graphics card. Power (pin 9) and I2C clock (pin 15). Usually these cables are made for short runs so they use a 22 gauge or smaller cable for the video. So really RGB is a subset of VGA. But there is nothing that would preclude you from terminating a VGA connector (correct name is D-Sub 15 or DE15) on a set of five RG-11 cables.
The smaller cables are what create ghosting.
Steve Kennedy-Williams
    • Kennedy-Williams.net
« Reply #7 on: November 23, 2011, 05:21:36 pm »
As the repair manager for an AV company, I'd add.
1. Field repair of BNC is much easier than VGA.
2. We use a RGBHV + 1, so we have a spare channel on each cable. one goes down, we don't have to replace the cable.
3. Easier to use locking connector. The bayonet style lock on BNCs is much easier to deal with than thumb screws.
Kellen Tyburski
« Reply #8 on: November 27, 2011, 08:03:27 pm »
Awesome responses, thanks guys. Right after posting this I ran out and bought Audio/Video Cable Installer's Pocket Guide by Stephen Lampen - which is some really great stuff..
Thanks again,
K
KT
Page created in 0.088 seconds with 22 queries.
