Author Topic: Driver for unloaded sub box?  (Read 7903 times)
Douglas R. Allen
    • http://-
« on: January 12, 2011, 08:00:02 PM »
I've been looking at a few drivers for a box I have. A peavey 1801-8 lt bw I have as a spare does measure ok in the box but I wanted to look at other drivers as well.
Box is 5.6 cubic feet after driver displacement is taken into account. It is tuned to 45hz. A 24 db per octave low cut will be used with 800 watts rms available but rms values around 200 watts will be the most expected.
The 3 drivers I'm looking at.
peavey 1808-8 sps bwx
Znom (ohms) 8
Revc (ohms) 6.71
Sd (Square Meters) 0.1237
BL (T/M) 16.26
Fo (Hz) 37.4
Vas (liters) 368.0
Cms (uM/N) 169.4
Mms (gm) 106.7
Qms 7.545
Qes 0.637
Qts 0.587
Xmax (mm) 4.60
Le (mH) 0.38
SPL (1W 1m) 96.7
No (%) 2.94%
Vd (cu. in. / ml) 69.4 / 1138
Pmax (Watts pgm.) 1000
Disp (cu. in. / ml) 228 / 3737
peavey 1808-8 cu bwx
Znom (ohms) 8
Revc (ohms) 5.93
BL (T/M) 23.12
Fo (Hz) 35.1
Vas (liters) 312.7
Cms (uM/N) 143.9
Mms (gm) 143.2
Qms 9.934
Qes 0.350
Qts 0.338
Xmax (mm) 4.6
Le (mH) 0.66
SPL (1W 1m) 97.7
No (%) 3.73%
peavey 1808-8 he bwx
Znom (ohms) 8
Revc (ohms) 5.10
BL (T/M) 17.77
Fo (Hz) 39.9
Vas (liters) 281.5
Cms (uM/N) 129.6
Mms (gm) 122.6
Qms 9.954
Qes 0.497
Qts 0.473
Xmax (mm) 2.0
Le (mH) 0.32
SPL (1W 1m) 97.5
No (%) 3.50
Vd (cu. in. / ml) 29.5 / 483
All 3 drivers sport the same 500 rms 1000 program 2000 peak rating.
Would one of the 3 above be better suited for the 5.6 cubic foot box?
index.php/fa/34710/0/
My old IBM 365 with my win speaker box program has crashed so I can't plug them in right now.
Any ideas?
Douglas R. Allen
Allen Audio
"The worst thing is."
"You can't teach common sense."
Page created in 0.058 seconds with 21 queries.
