Hi Jeff,
ive used the EAW UX8800 processor from the moment i got the Danleys in just the ordinary DSP type processor mode,ive buzzed all my cables,checked all my loudspeaker cables.
All the cables are Van Damme cables which are the touring choice of cables in the UK,all connectors are Neutrik.
The Ux8800 is set to
25hz LPF and 79.2 HPF for the Subs
79.2 LPF and 20khz HPF for the Tops/ 24db BW for the slopes with a 6db BW for the high end.
Centre speaker set to 120 LPF/20KHZ HPF
No Compression or Limiting on the UX8800.
Amps set to 35db of input gain, UX8800 set to normal no gain added or subtracted.
Im Using a Digital desk....So i ask does the Latency of the desk and the latency of the processor have bearing on sound,the processor i believe to be 3.13ms of latency.so say the desk had 1.5ms of latency,that would be nearly 5ms of latency plus any time alignment issues reguarding tops to subs.I do apologise for not understanding things but its a learning process.
many thanks Leon
