Robert Patch brought his shiny new JTR loudspeakers up to my place today for me to put them through their paces and get his system firing on all cylinders.
He bought a pair of JTR Triple 12 tops, and a pair of Orbit Shifter subs.
Specs for the speakers can be found here:
Triple 12:
http://jtrspeakers.com/portable/triple-12x/Orbit Shifter:
http://jtrspeakers.com/portable/orbit-shifter/Tops were being powered with a Crown IT4000.
Subs were being powered with a Crown IT6000.
First up, the Triple 12.
The Triple 12 has 3 handles on each side of the cabinet. It's pretty easy to move around, and isn't overly heavy. It's around the same size & weight as the JBL SRX722/EV QRX212. It's got the usual spray coating as well, and overall has a nice build quality. Some rubber feet on the bottom would be a nice touch though...
On to the measurements:
All measurements were taken ground plane, outdoors.
I have no idea what happened to my screenshot, but it's fucked to all hell. The phase response is pretty flat in the HF, but there were a few weird 180 degree shifts that I couldn't get rid of...
The Orange trace is the raw response with no processing.
The blue trace is the response with an added 24dB LR HPF filter at 80hz.
The Purple trace is with EQ applied.
The Triple 12 seems to roll off fast about 8k, and has a weird dip around 300hz, but is otherwise pretty flat. I ended up using 4 EQ filters total.
EQ1: -3 @ 560hz, Q3
EQ2: -2 @ 5k, Q4
EQ3: -3 @ 8k, Q6
EQ4: +4 @ 9k, Hi Shelf
Nothing too crazy. The box still seems to struggles past 12k, but it's not terrible.
Listening tests:
The Triple 12 has an interesting sound to it. I say interesting, because it's not like what I'm used to hearing. It's not in your face, it's not harsh and it's not what I'd call super smooth. It seemed to have a boxy low mid sound and missing midrange. The top end is crispy, but not super Hi-Fi. Everything is there, it's just, different. I feel these cabs would work well for acoustic type music, not so much rock and roll.
When cranked the HF starts to break up. The 1" compression driver simply doesn't keep up with the rest of the box. You either have to dial the HF back and lose that extension, or simply not turn them up as loud. The cabinets do stay pretty clean and pretty smooth as you crank them up, but the HF struggles as you approach limit on the IT4000.
Overall, they're not bad cabinets at all. They're better sounding then some offerings. If I really spent a few days and gigs with them, I could probably get them pretty rockin', but it would take some work. I'd rather have a JBL SRX or EV QRx if I was spending the $$.
Orbit Shifter:
The Orbit Shifter is a single 18" horn loaded subwoofer. It has 2 handles on the bottom, and 2 handle cutouts on the rear. It tilts back onto wheels and is pretty easy to move around with one person. They're very similar in size to a JBL SRX728/Danley TH115.
However, it just SCREAMS DJ grade to me. It needs a full faced grill. It just looks ridiculous to me.
Measurements:
The purple trace is the raw response.
The green trace is with a 24dB LR LPF @ 80hz, and an 18dB BW HPF @ 35hz.
The pink trace is final with EQ.
A single Orbit Shifter does very well from 40hz - 80hz. Due to it's horn loaded nature it does get very efficient above 80hz, and it required a few out of band EQ cuts to smooth it out.
EQ1: -6 @ 100hz, Q15
EQ2: -15 @ 130hz, Q15
EQ3: -3 @ 73hz, Q2
When combined with the Triple 12, the system plays very well together.
Green = sub
Pink = Top
Orange = full range
Listening Tests:
A single Orbit Shifter is not bad at all. It reminds me of the Growler tonality. It's not boomy, but not super tight either. It's very smooth throughout it's bandpass and does very well with dance music. It bangs out the low notes just fine. I was able to bottom it out with some dance tracks, before the IT6000 hit limit. A single Orbit Shifter does seem to have more output than a pair of Growlers. They'd be a good alternative to everyone's favorite MI dual 18's.
Overall, they're good subs. I'd never buy one just because of the way they look, and it's a shame. They are good sounding subs with a good amount of output(I imagine a block of 4 would be very impressive).
Evan
