Author Topic: QSC HPR 152i  (Read 7918 times)
Donny Linhard
QSC HPR 152i
« on: January 02, 2011, 09:28:48 PM »
OK i have a pretty good question.
As you all know QSC uses Celestion Drivers in there cabinets.
The other night one of my woofers in my QSC HPR 152i ceased up
the driver in the cab is  a CELESTION,FTR-3070C-T5452_GPE
now I have an extra CELESTION,FTR-3070E,T5468_GPE laying around
the Ohms the 3070C is an 8 ohm driver.
The 3070E SAYS ON the driver that it is a 4 ohm.
But when i go through the manuals for it it says its an 8ohm driver.
woofers are Identical in appearance.
Here are the specs of the 3070C and the 3070E
FTR15-3070E
General Specifications
Nominal diameter (mm/in) .......................................381/15
Power Rating (AES, W rms)...........................................400
Nominal impedance (Ω) ...................................................8
Voice coil diameter (mm/in) ...................................76.2/3.0
Magnet type  ............................................................ .Ferrite
Chassis type ...............................................Cast aluminium
Sensitivity (dB)  ............................................................ ...97
Frequency range (Hz) ............................................40-4000
Coil  material..................................................Ro und copper
Former  material..................................................Gl ass fibre
Cone material.................................Glass loaded paper with
...........................................weather resistant impregnation
Surround  material............................................Cloth-se aled
Suspension.................................................. .............Single
Xmax (mm/in)  .......................................................5.5/0 .22
Gap depth  (mm/in)................................................9.0/0 .35
Voice coil winding width (mm/in)..........................20.0/0.79
Small Signal Parameters
D  (m/in)...................................................... ........0.33/8.38
Fs (Hz)  ............................................................ ............45.3
Mmd  (g/oz)...................................................... ..74.54/2.63
Mair  (g/oz).....................................................1 4.149/0.499
Qms......................................................... ...................3.07
Qes......................................................... ....................0.46
Qts  ............................................................ .................0.40
Re (Ω)  ............................................................ ............5.36
Vas (lt/ft3)  ........................................................143. 85/5.08
BI (Tm)  ............................................................ .........17.24
Cms (mm/N)  ............................................................ ....0.14
Rms (kg/s)  ............................................................ .......8.22
Le (mH)  ............................................................ ............ 1.3
Mounting Information
Overall diameter (mm/in) ....................................385/15.16
Overall depth (mm/in)...........................................161/6.34
Cut-out diameter (mm/in) ...................................351/13.82
Mounting slot dimensions (mm/in)..........7 x 10/0.28 x 0.39
Number of mounting slots ................................................8
Mounting slot PCD range (mm/in) .....365-375/14.37-14.76
Unit weight  (kg/lb).................................................6.4/ 14.1
Packed Dimensions & Weight
Single pack size W x D x H (mm/in) ...........435 x 435 x 200
............................................................ ./17.1 x 17.1 x 7.9
Single pack weight (kg/lb) .....................................7.7/17.0
Multipack (36) size W x D x H (mm/in) ..........1210 x 1050 x
.....................................................980/47. 6 x 41.3 x 35.4
Multipack (36) weight (kg/lb) .................................278/613
FTR15-3070C
Nominal diameter (mm/in) ...................................... 381/15
Power rating (AES, W rms) ......................................... 400
Nominal impedance (Ω) ................................................. 8
Voice coil diameter (mm/in) ........................................ 76/3
Magnet  type........................................................ .... Ferrite
Magnet weight (kg/oz)..............................................2.3/81
Chassis type.............................................. Cast Aluminium
Sensitivity (dB)  ............................................................ .. 99
Frequency range (Hz) ........................................... 40-4000
Coil material ............................................... Round copper
Former material................................................. Glass fibre
Cone material .................. Glass loaded paper with weather
........................................................resi stant impregnation
Surround material .......................................... Cloth-sealed
Suspension  ............................................................ . Single
Xmax (mm/in) ...................................................... 3.0/0.12
Gap depth (mm/in)............................................. 10.0/0.39
Voice coil winding width (mm/in) ....................... 16.0/0.63
D (m/in) .......................................................... 0.33/12.99
Fs (Hz)  ............................................................ .............. 40
Mmt (g/oz) ...................................................... 84.15/2.97
Mmd (g/oz) ...................................................... 70.00/2.47
Qms  ............................................................ .............. 7.10
Qes  ............................................................ ............... 0.38
Qts  ............................................................ ............... 0.36
Re (Ω)  ............................................................ .......... 6.50
Vas (lt/ft3) ........................................................ 208.0/7.34
Bl (Tm)  ............................................................ ....... 18.70
Cms (mm/N)  ............................................................ .. 0.20
Rms (kg/s)  ............................................................ ..... 2.86
Le (mH)  ............................................................ .......... 0.59
Overall diameter (mm/in) .................................. 385/15.16
Overall depth (mm/in).......................................... 158/6.22
Cut-out diameter (mm/in) .................................. 351/13.82
Mounting slot dimensions (mm/in)......... 7 x 10/0.28 x 0.39
Number of mounting slots ............................................... 8
Mounting PCD range (mm/in) .......... 365-375/14.37-14.76
Unit weight (kg/lb)................................................ 6.3/13.8
Single pack weight (kg/lb) ................................... 7.7/17.0
Multi pack (36) size W x D x H (mm/in) ..............................
..............................1200 x 1000 x 980/47.2 x 39.4 x 38.6
Multi pack (36) weight (kg/lb) .............................. 278/613
will it hurt to drop the 3070E driver into my 152i 2 way cabinet?
the 3070E driver is out of a HPR 151i.
Please give me some input. As you can see i'm a bit of an amateur compared to some of you.
MUCH THANKS!!!!
Silas Pradetto
Re: QSC HPR 152i
« Reply #1 on: January 03, 2011, 11:33:32 AM »
If you can get a DC resistance off the seized driver, and it matches the other driver you have, then go for it. Otherwise, get the right one.
Page created in 0.039 seconds with 20 queries.
